Autoguider
Autoguider
Shoestring GPUSB Auto-Guider Kit
A low cost, practical, auto-guiding connectivity kit
Auto-Guiding solution with Shoestring's GPUSB interface
GPUSB plugs directly to PC USB Port
RJ-12 cable connects to mount
Software compatible with:
ASCOM platform
AstroArt
MaxImDL
MaxImEssensials
MaxDSLR
K3CCDTools
Guidemaster
GuideDog
...and others (see below)
Shoestring GPUSB Auto-Guiding Kit
The Auto-Guider kit contains:
GPUSB Guide Port Interface (PC USB port).
Includes 5-foot coiled RJ-12 cable normally available seperately.
Order No. Price (inc_VAT) Shipping Delivery click to purchase
SSAGKITU £ 54.40 £ 7.00
User Manual 1.2
(PDF) Guide Port Cabling 1.0
(PDF) GPUSBCheck 1.0
(EXE) GPUSB ASCOM Driver
(EXE)
Outline
It is now easy and inexpensive to set up your own autoguiding system. You'll need:
PC or laptop computer (e.g. Windows 2000/XP).
Camera dedicated to auto-guiding (e.g. Meade DSI, Meade DSI Pro, etc).
An interface between the computer and the mount (Shoestring GPUSB kit supplied here).
Autoguiding software (e.g. AstroArt see below).
With the control software the computer can talk to your telescope mount and direct it's motion. Many telescopes come with a six pin port that looks like a phone jack. This is called an RJ-12 connector.
Typically, a hand controller or CCD autoguider is plugged into this port. Until now, anyone wanting to implement camera auto-guiding that had this type of port would have to buy a relay box that would connect to the parallel port of the computer, and then would need to be wired to the guide port. These relay boxes are fairly large, and are one more thing that requires a power source.
Techical Details
The GPUSB guide port interface adapter plugs directly into a USB port on your computer or a USB hub attached to your computer. Using an RJ-12 cable, the adapter connects to the guide port of your telescope mount. This guide port interface uses optocouplers to electrically isolate the computer from the telescope, eliminating a possible source of electrical interference. This interface adapter requires no external power source since it receives its power via the USB cable. More information can be found in the user manual.
Warning About Cables
The use of improperly wired cables with mounts can result in damage to the electronics in the mount, as well as damage to the interface adapter. The importance of using a properly wired cable cannot be stressed enough. If you choose to make or buy your own from another source, please be sure it is built per the description in the user manual.
ASCOM Compatible
Shoestring Astronomy has developed an ASCOM driver for the GPUSB. Using this driver, any autoguide software package that supports the ASCOM standard will work with the GPUSB. Most telescope mounts are ASCOM compliant. Therefore even if your auto-guiding software package does not support the GPUSB natively, the chances are that it can still be made to work via the ASCOM software platform. Please follow these steps in order:
Download and install the ASCOM platform from the ASCOM website.
Install the Shoestring Astronomy's GPUSB ASCOM Driver for the GPUSB from the link above.
Missing A USB Port?
If your computer does not have a spare USB port but it has a parallel port, then you can use the Shoestring GPINT-PT Auto-Guider Kit that plugs directly to your computer's parallel port.
GPINT-PT.
Telescope-Mount Support
Any ASCOM compatible mount with an ST-4 compatible autoguider port should work with this adapter. Mounts tested so far include:
CG5 (requires Shoestring's Guide Port Conversion Kit)
EQ3 (requires Shoestring's Guide Port Conversion Kit)
EQ5 (requires Shoestring's Guide Port Conversion Kit)
EQ6 SkyScan
HEQ5 SkyScan
Vixen SPHINX
Vixen GPDX via SkySensor 2000 (requires Shoestring's SkySensor 2000 coverter)
Vixen Altux via SkySensor 2000 (requires Shoestring's SkySensor 2000 coverter)
Losmandy GM-8 or G-11, without the Gemini box.
Losmandy GM-8 or G-11, with new-style Gemini box (circular DIN connects to connect motors).
Takahashi EM-10 (requires Shoestring's Guide Port Converter for Takahashi mounts)
Meade LX-200.
Meade LX-90.
Celestron Nexstar i-series.
Celestron Celestar 8.
Celestron Advanced Series GoTo.
Celestron CGE.
Orion Atlas EQ-G style.
Gemini G-41.
Astro-Physics AP900 QMD.
JMI NGT.
Tom O. Equatorial Platform.
With modification, you can also add an ST-4 compatible autoguide port to your EQ style mount. See the Guide Port Conversion Kit for details.
System Testing With GPUSBCheck
GPUSBCheck is a simple, free software application by ShoeString Astronomy that you can use to verify that your GPUSB, computer, and scope mount are all together working properly. You can download this using the link above. You should use this the first time you set up your system. You can also use it as a debugging tool anytime your system is not functioning properly. If your system works fine with GPUSBCheck, but not with your third-party software, then the problem most likely lies with the third-party software and you should contact them for technical support. If your system does not work with GPUSBCheck, then you should contact Shoestring Astronomy for technical support.
Software Support For Auto-Guiding
The Shoestring GPUSB guiding kit (supplied here) is currently supported by the following software applications.
Software Application Shoestring GPINT-PT Shoestring GPUSB
(supplied here)
GuideDog by barkoSoftware Yes Yes (via ASCOM)
MaxIm Essenstials by Diffraction Limited Yes Yes (via ASCOM)
MaxIm DL by Diffraction Limited Yes Yes (v 4.52)
MaxDSLR by Diffraction Limited Yes Yes (v 4.02)
AstroArt by MSB Software Yes Yes
K3CCDTools by K3 Yes Yes (v 3.00)
Guidemaster by Matthias Garzarolli Yes Yes
Astro IIDC (Macintosh) by ASC no Yes
AstroVideo by COAA Yes no
MetaGuide by Frank Freestar8n Yes Yes
PHDGuiding by Craig Stark Yes Yes (natively or ASCOM)
http://www.opticstar.com/Run/Root/Root-Home.asp
ASCOM platform
AstroArt
MaxImDL
MaxImEssensials
MaxDSLR
K3CCDTools
Guidemaster
GuideDog
User Manual 1.2
(EXE)
Outline
Techical Details
ASCOM Compatible
Missing A USB Port?
GPINT-PT.
EQ6 SkyScan
HEQ5 SkyScan
Vixen SPHINX
Meade LX-200.
Meade LX-90.
Celestron CGE.
Gemini G-41.
JMI NGT.
(supplied here)
Autoguider
GPUSB prisla asi po tydnu (platba 65$ pres Paypal).
Je to v podstate krabicka, ktera prevadi USB kabel/signal na RJ12 (telefonni) konektor a signal pro Autoguider vstup vetsiny montazi (v mem pripade CEL CG5 GT).
Po prvnich pokusech s novou webkou Philips na Lidlskopu jsem zatim uspech nezaznamenal. Vetsina free autoguiding SW, ktere by s tim mely byt kompatibilni hlasi ruzne chyby. >:(
Jediny ktery projevil nejakou aktivitu byl PHDGuiding, ktery po identifikaci hvezdy zacal provadet nejakou kalibraci, behem ktere mu ale hvezda unikla ze zorneho pole a pak se zatahlo...
Bude to jeste delsi boj.
Pokud uz to mate nekdo rozchozene prosim podelte se o zkusenost...pokud zvitezim take dam vedet...
Pavel Vabrousek
Autoguider
Zvažuji následující montáže pro Maksutova 150/1900mm buď LXD75 od Meade,kde je autoguiding softwarově přes Autostar suite,vyšší cena 27500 Kč.Nebo vzít montáž Skywatcher HEQ5 Syntrek cca 16000 Kč.Autoguiding přes GPUSB Auto-Guider Kit.Na Celestron CG5 je třeba ještě dokoupit
Shoestring's Guide Port Conversion Kit a zabudovat do ručního ovladače.Skywatcher HEQ5 toto netřeba.
PHDGuiding software je jediný s freeware který je stabilní a nehlásí chyby.Až budete pointovat přes tento software prosím o sdělení postřehů,předem děkuji.
Autoguider
Meade má vše v Autostar suite na LXD75,LX90,200 přizpůsobeno kamerám DSI a LPI.Shoestring GPUSB Auto-Guider Kit umí využívat k pointaci kamery DSI což může být pro jejich majitele výhodou pokud mají montáž jiné firmy Celestron,Synta,Vixen....
Nebylo by špatné pokud by firma SUPRA dovezla pár kousků Shoestring GPUSB Auto-Guider Kit a rozchodila na HEQ5,EQ6,CG5 montážích a napsala recenzi na POSEC.Poznatky by se hodily pro řadu astrofotografů.
Autoguider
vaclav1 napsal: Shoestring GPUSB Auto-Guider Kit umí využívat k pointaci kamery DSI což může být pro jejich majitele výhodou pokud mají montáž jiné firmy Celestron,Synta,Vixen....
Nebylo by špatné pokud by firma SUPRA dovezla pár kousků Shoestring GPUSB Auto-Guider Kit a rozchodila na HEQ5,EQ6,CG5 montážích a napsala recenzi na POSEC.Poznatky by se hodily pro řadu astrofotografů.Nechci Ti brat iluze, ale to, o cem tady basnis, neni autoguider. Je to jen kabel na pripojeni notebooku na autoguider port montaze pres USB, misto obvykleho paralelniho portu. Autoguider musi byt softwarovy v tom notebooku ( viz seznam kompatibilniho SW ). Nevim, co na takovem kabelu recenzovat. Rozhodujici bude spravny software, ktery si bude rozumet s pouzitou kamerou i tim USB kabelem.
e-mail : mpec(at)cce(dot)cz&&
Autoguider
vaclav1 napsal: Na Celestron CG5 je třeba ještě dokoupit
Jak pisi vyse zatim jsem nezvitezil, takze je brzo hodnotit, ale mam pocit ze pro mou CG-5 (GT) staci ten GPUSB, ktery se pripojuje telefonim kablikem primo do autoguider konektoru na montazi.
Jinak zatim jsem s tou CG5 docela spokojen ale primou zkusenost pro poravnani s HEQ5 nebo LXD 75 nemam.
Cenove je CG5 (A-GT) ted docala zajimava (u Supry) -> 22500 Kc vcetne C80ED, ktery pokud nepotrebujes tak hrave prodas. 6500 ti za nej dam treba i ja...
HEQ5 mi prisla za podobny peniz sice masivnejsi, ale nema GO-TO (+9000 za novou rucku). LXD je cenove nekde jinde...
Pavel Vabrousek
Autoguider
Jen pro uplnost : rozhrani pro autoguider je na vetsine montazi velice jednoduche - na tom konektoru RJ-12 se spinaji 4 vodice proti zemi, coz odpovida 4 smerum pohybu. To je vse. Takze pokud u nejake montaze port pro autoguider neni, lze jej snadno vytvorit - konektor se pripoji paralelne k tlacitkum rucniho ovladace pohonu. Na to neni treba nic kupovat. Samostatny port na montazi ma ovsem vetsinou moznost samostatne volby rychlosti pointace, nezavisle na "rucnich" jemnych pohybech.
Takze v pripojeni autoguideru nehledejte zadnou vedu, je to jednoduche a ten GPUSB kit jen spina ty 4 draty podle prikazu, ktere mu autoguider v pocitaci posle pres USB.
Vyjimkou jsou nektere novejsi montaze Meade ( napr. LXD75 ), ktere klasicky autoguider port nemaji a guider musi s montazi komunikovat pres seriovy port v jejim vlastnim protokolu.
A jeste jednou : ten kit neni autoguider, jen spina ty 4 draty. Jak je ma spinat, to mu rika SW v pocitaci pres USB port. Takze funkce autoguideru jsou dany tim softwarem, ne tim kitem.
- astropintr
Autoguider
Ahoj, v budoucnu bych chtěl upgradovat svoji montáž na Sky scan a budu moci zkusit pointaci přes notebook. Software jsem si našel na stránkách MMyse. Potřebuji nějakou ccd kamerku pro pointování. Našel jsem docela jednu v cenové relaci, která je ještě pro mě přístupná - NEXIMAGE KAMERA. Chtěl bych se zeptat, zda ta by byla dostatečná pro autopointaci přes notebook. Chtěl bych pointovat přes dalekohledy Skywatcher 70/500 a Skywatcher ED 80/600. S oběma dalekohledy musím vložit kamerku až za Barlow 2 x kvůli dlouhému ohnisku mého velkého dalekohledu. Je tato ccd dostatečná? Nebude s tím nějaký problém?
Skywatcher Newton 250/1200 na EQ - 6&&Skywatcher ED refraktor 80/600 na EQ - 6&&Canon EOS 350 D neupravený&&triedr 10x 50.&&binar 25 x 100
Autoguider
astropintr napsal: Ahoj, v budoucnu bych chtěl upgradovat svoji montáž na Sky scan a budu moci zkusit pointaci přes notebook. Software jsem si našel na stránkách MMyse. Potřebuji nějakou ccd kamerku pro pointování. Našel jsem docela jednu v cenové relaci, která je ještě pro mě přístupná - NEXIMAGE KAMERA. Chtěl bych se zeptat, zda ta by byla dostatečná pro autopointaci přes notebook. Chtěl bych pointovat přes dalekohledy Skywatcher 70/500 a Skywatcher ED 80/600. S oběma dalekohledy musím vložit kamerku až za Barlow 2 x kvůli dlouhému ohnisku mého velkého dalekohledu. Je tato ccd dostatečná? Nebude s tím nějaký problém?
Ten SW ale s kamerkami Celestron a Meade nefunguje. REsp. funguje, ale neumí vyvolat dialogové okno pro nastavování kamery, takže je to nanic. Oba výrobci totiž nahradili standardní dialogové okno WDM ovladače přímo jejich aplikací, která komunikuje s kamerou nějakým nestandardním způsobem, který jsem nenašel nikde popsaný. Použij možná raději webkameru, bude i levnější. S LPI, Neximage a podiobně budeš muset použít jejich SW (ten si zase bude rozumět jen s montáží stejného výrobce pravděpodobně) Prostě si dopředu vše prozkoumej, než to koupíš.
- astropintr
Autoguider
MMys napsal:
Díky, to je pro mě zásadní informace, můžeš mi nějakou webkameru doporučit, která uričtě funguje přes tvůj software?
Díky za odpověď.
Pavel
Díky za odpověď.
Pavel
Autoguider
S mým SW fungují všechny webkamery, ke kterým je WDM driver (naprostá většina současných). Z hlediska citlivosti a dostupnosti doporučuji pouze jednu: Philips SPC900NC
- Lightsscope
Autoguider
MMys napsal: S mým SW fungují všechny webkamery, ke kterým je WDM driver (naprostá většina současných). Z hlediska citlivosti a dostupnosti doporučuji pouze jednu: Philips SPC900NC
Možná tkaová hloupá otázka, mohl bych si to zjistit sám, ale nejsem z oboru: kde je nejlevnější a za kolik koupit tuto kameru? Díky, Hora.
- Alien_MasterMynd
Autoguider
hora napsal:
Možná tkaová hloupá otázka, mohl bych si to zjistit sám, ale nejsem z oboru: kde je nejlevnější a za kolik koupit tuto kameru? Díky, Hora.Tady ji sezenes za 1603+248 doprava. Ja ji tam kupoval v prosinci asi o 200 draz.
Ale hledani point. hvezdy neni nic moc, chce si to nejdriv pomerne presne najit okularem a pak doladit kamerou. Ta kamera totiz nema az takovou citlivost, a aby kloudne videla hvezdy, tak jsem musel mit docela dlouhy cas zaverky, z cehoz vyplyva docela velka setrvacnost pri pohybu obrazu hvezdy po snimaci. Taky jsem docale bojoval s upointovanim snimku, coz bylo asi zpusobene timhle, nicmene nejak extra jsem neexperimentoval.
Tr. 8x30,10x50,20x50
Autoguider
Samozřejmě, že oproti vysoce citlivé ČB TV kameře s ExView HAD senzorem to je slabší. Kamera + grabovací USB nebo PCMCIA karta je lepší řešení, ale také podstatně dražší.
- astropintr
Autoguider
Díky za inormaci, jakmile budu mít upgrade mojí montáže, zkusím si tuhle web kameru koupit. Má někdo zkušenost, do jaké mag jste schopni nalézt hvězdy? Samo, vím, že to závisí na přístroji, ale zajímalo by mě to.
