Mlhovina NGC 7635 - Bublinka
ccerdo
#211
Příspěvek od ccerdo »
Je to myšleno jako objekt..... O chlazené kameře se mi může akorát zdát :-[
Jura
ceres
#212
Příspěvek od ceres »
Kedze som na mailing-liste Kena Crawforda, dostavam vsetky jeho nove snimky. Tentoraz si to nemozem nechat len pre seba :o:
The Bubble and Super Nova Remnant
Hello,
I have a new image for you that is a bit special to me:  a famous bubble of hot gas that is over 6 light years across blown from the powerful stellar winds of a star 40 times more massive than the sun.  The star is known as a Wolf-Rayet star and they are very rare and powerful.  This object is known as the bubble nebula and the  shell of glowing  gas looks blue in this image from ionized oxygen.   It is imbedded in a surrounding Hydrogen (HII) region called Sharpless 162 that creates wonderful structures that look like pillars and mountains.  The golden colored pillars are much denser gas and the closer they are to the WR star the brighter they are because of the intense ultraviolet light and stellar winds.
I have collected over 25 hours of data on this target to reveal  some faint, rusty red strings (filaments) that start from the left center to the lower left.  These filaments are part of a Super Nova that exploded several thousand years ago.  The super nova remnant was discovered in 2005 by the Canadian Galactic Plane Survey in 2005 in radio wavelengths.  The first optical image was taken with the 4 meter telescope at Kit Peak by T.A. Rector from the University of Alaska.  I have not seen any other images of this SNR and I am very pleased that I was successful in capturing some of the filaments.
http://www.imagingdeepsky.com/Nebulae/Bubble/Bubble.htm
If you are interested, here is a link to Dr. Travis Rector’s shot showing all of the SNR with the 4 meter telescope and the Mosaic camera (several million dollars worth of telescope).
http://www.noao.edu/image_gallery/html/im1029.html
Ken Crawford
www.aicccd.com
Konihlav
#213
Příspěvek od Konihlav »
25 hodin dat, 20" RCOS, KAF-9000, Rancho Del Sol ... co k tomu dodat? nic :-)
BTW na bublinku se taky chystam :-)
Roman (Rick)
#214
Příspěvek od Roman (Rick) »
No tak to je velice dobrý snímok. Na druhej strane s takou technikou a oblohou sa ani iný snímok nedá čakať.
PS: nie je to už trochu starší snímok. Už som ho videl na jeho stránke dobre dávno (pred pol rokom, rokom ??). Či tam zase nezbieral nejaké nové dáta?
ceres
#215
25 hodin dat, 20" RCOS, KAF-9000, Rancho Del Sol ... co k tomu dodat?...
Ked si precitas ten jeho popis, tak pise, ze podobne detailnu snimku urobili len cez 4m na Kit Peaku pomocou Mosaic Camera v sumarnej hodnote niekolkych milionov USD. Kenovo vybavenie stalo "len" necelych 100.000 USD ::)
Konihlav
#216
tak to jo to ma "za babku" ;D
Alien_MasterMynd
#217
Ked si precitas ten jeho popis, tak pise, ze podobne detailnu snimku urobili len cez 4m na Kit Peaku pomocou Mosaic Camera v sumarnej hodnote niekolkych milionov USD. Kenovo vybavenie stalo "len" necelych 100.000 USD  ::)To je fakt, kdyz jsem porovnaval oba snimky, nejak jsem nevidel velke rozdily v zachycenych detailech... Jsem si rikal, proc tam odkazuji ten snimek ze 4m dalekohledu, kdyz je to prakticky nastejno :-)
Tr. 8x30,10x50,20x50
Froggy
#218
Příspěvek od Froggy »
Pavle, některé Tvé hlášky mě dokážou fakt pobavit  ;D Dík za ně  ;)
http://astrofotky.cz/~Froggy
ED refraktor SW 80/600, refraktor SW 100/500, CCD Atik ATK-16, CCD Meade DSI Pro, EQ-6 Sky Scan
#219
Ta struktura kolem vlastní Bublinky je velmi složitá. Jde o to , co se zrovna fotograf při zpracování považuje za potřebné ukázat.
Tady je dnešní snímek vlastní mlhoviny ponořené do oblaku plynu :
podrobnosti:http://astrofotky.cz/gallery.php?show=. ... 442167.jpg
ladaS
#220
Příspěvek od ladaS »
Ahoj, tak to je Milane moc pěkný snímek plný detailů.
N200/800
refr.70/500
Canon EOS 7D MK II.,CCD QHY8
NEQ6SS
Konihlav
#221
jeee, tak to jsme v noci ze SO na NE fotili stejny objekt ja ho ale vzal moc wide-field 330tkou, protoze jsem puvodne mel jiny plan (no vlastne jsem tu noc prokaucoval bez planu a pak nahodne zkousel neco zajimaveho najit).
ta noc byla nejaka podezrele dobra, fotil jsem bublinku 10ti minutovkama (bohuzel pouze) a subexpozice vypadaji moc pekne, tak se tesim na vysledek...
jo Milane, mas recht, jsem zvedav, zda sam ukazu bud okolni mlhoviny, nebo neprepalene centralni hvezdy ;-)
Konihlav
#222
tak jsem se rozhodl, kdyz to ma byt wide-field, ze ukazu spise okolni mlhoviny, je jich tam dost a jsou pekne :-)
takze konecne zpracovany obrazek:
:-) rekl bych, ze to je jeden z mych NEJ :-)
#223
Pavle ty se umíš pochválit A navíc oprávněně! Pěkná kompozice, detaily i zpracování. Jsem zvědav, co ti tam hnidopichové zase najdou :D
deavi
#224
Příspěvek od deavi »
No Pavle po dlouhé době snímek, který se Ti opravdu podařil, pěkně se na to kouká, jenom bych možná snímek malinko zesvětlal. Ale to už je malinký detail ;)
http://www.astronom.cz/deavi/
-karneades-
#225
Příspěvek od -karneades- »
Pavle, moc dobrý, lépe už to s tím barevným shitem od Borgu nepůjde :), chtěl jsem ji cvaknout taky, ale 400mm mi přišlo mac krátkých, když teď vidím, jak je ta kompozice hezká, tak ji obšlehnu, díky za inspiraci.
