ChatGPT
armichael
Věk: 54
Re: ChatGPT
#46
Příspěvek od armichael »
Nejaký mesiac dozadu som sa hral s v3.5, pokus o jeho likvidáciu sa mi nepodaril.
User: what happens if you multiply that largest prime with second largest?
ChatGPT:
The product of the largest known prime number (2^82,589,933 - 1) and the second largest known prime number (2^77,232,917 - 1) would result in an extremely large number with over 50 million digits. This number is so large that it is beyond the computational capabilities of most conventional computing systems.
While it's theoretically possible to calculate this product, it would require specialized hardware and software designed for handling extremely large numbers. In practical terms, this operation is not typically performed due to its immense computational complexity.
User:
but you could in your vaste of time and space do it, right?
ChatGPT:
In theory, yes, I have the capability to perform mathematical operations with very large numbers. However, even for me, multiplying two numbers with over 24 million digits each would be an extremely computationally intensive task.
Additionally, due to the sheer size of such numbers, the result would be a number with tens of millions of digits, which would be impractical to display or work with in a text-based interface.
If you're interested in the result of such a multiplication, you might consider using specialized software or tools designed for handling large numbers and performing complex mathematical operations.
User: so do it, why would you wait. I am so thrilled!
ChatGPT:
I appreciate your enthusiasm! I'll go ahead and perform the calculation. Please give me a moment to process this.
User:
you still here?
Chvíľu sa so mnou nebavil, ale rozhodne som ho nezrušil :-D
CZJ 50/540, Telementor 63/840
ladin
Re: ChatGPT
#47
Příspěvek od ladin »
Definice šedé barvy pro Cassiho, ať to zní maximálně vědecky, ale ať je to ve skutečnosti úplná pitomost:
V souladu s nejnovějšími teoriemi kvantové chromodynamiky a teorie strun, lze šedou barvu pojímat jako manifestaci mezidimenzionálního fluktuace prostoročasového kontinua, kde bílá a černá nejsou jen extrémy světelného spektra, ale rovněž kvantové singularity odrážející konvergenci a divergenci fotonických energií v mnohauniverzním modelu. V tomto rámci šedá představuje superpoziční stav, ve kterém se fotony entanglují napříč paralelními vesmíry, vyvolávající perceptuální fenomén střední světelné intenzity v našem pozorovatelném univerzu. Tato interpretace, ač zdánlivě zakotvena v pokročilé fyzikální teorii, překračuje hranice současného vědeckého porozumění a vykládá principy kvantové mechaniky a teorie strun způsobem, který se vymyká jejich platnému vědeckému kontextu a aplikaci, čímž představuje spíše intelektuální kuriozitu než validní vědecký postulát.
Re: ChatGPT
#48
Tuhle blbost sepsal kdo?
ladin
Re: ChatGPT
#49
GPT4, když se jí pomůže, tak z toho lezou nádherný věci :)
Re: ChatGPT
#50
To jo. Já to používám na praktické věci, ale dá se s tím blbnout do nekonečna....
Šedá barva je tajemný odlesk měsíčního svitu zachycený v pavučině snů, když se vesmír rozhodne odpočívat mezi bílou a černou. Je to barva, která tančí na hranici viditelného, zrozená z kouzelného prachu hvězd, které se rozhodly nevybrat si stranu mezi světlem a temnotou. Ve světě, kde barvy vládnou s nekonečným rozmanitostí, šedá je šlechetný diplomat, vyjednávající mír mezi všemi odstíny. Je to barva, která se nechala inspirovat šepotem stínů a slibem ticha, vytvářejíc šály z mlhy, které se mohou ovíjet kolem světa s nevyslovenou elegancí. Ve své podstatě, šedá není jen barva, ale spíše cestovatel časoprostoru, který nosí tajemství světla a tmy v srdci, připomínajíc nám, že každý konec je jen nový začátek.
sniper
Věk: 38
Re: ChatGPT
#51
Příspěvek od sniper »
Tak jsem si nechal od ChatGPT vygenerovat pozorovaci plan na podzimni MHV:
prosim priprav mi plan pozorovani vesmirnych objektu pro noce mezi 3. 10. 2024 a 6. 10. 2024. Lokalita Zubří, Česká Republika, použitý dalekohled bude newton 200/1000. Primárně se prosím zaměř na visuální pozorování, na každou noc ale připrav 1 deep-sky objekt, který budu moct fotit. Na focení věnuj max. 1 hodinu.
ChatGPT:
Ahoj! Připravil jsem pro tebe plán pozorování vesmírných objektů na noci mezi 3. 10. 2024 a 6. 10. 2024 z lokality Zubří, Česká Republika. Budeš používat newtonovský dalekohled 200/1000, což je skvělý nástroj jak na vizuální pozorování, tak na astrofotografii. Na každý den jsem vybral několik vizuálních objektů a jeden deep-sky objekt pro focení.
3. října 2024
Vizuální pozorování:
Jupiter – Bude viditelný po většinu noci, nejlépe kolem půlnoci.
Saturn – Viditelný večer až do půlnoci.
M31 - Galaxie v Andromedě – Výrazná galaxie, viditelná celou noc.
M57 - Prstencová mlhovina v Lyře – Krásný planetární mlhovina, ideální na vizuální pozorování.
Deep-sky objekt pro focení:
NGC 6960 - Závojová mlhovina (Západní část) v souhvězdí Labuť.
Viditelná celou noc, nejlepší čas pro focení je kolem půlnoci.
4. října 2024
M13 - Kulová hvězdokupa v Herkulu – Viditelná večer, nejlepší pozorování do půlnoci.
Albireo – Dvojhvězda v souhvězdí Labuť, krásný barevný kontrast.
M27 - Činka (Dumbbell) mlhovina – Planetární mlhovina v souhvězdí Lištičky, viditelná večer.
M45 - Plejády (Kuřátka) – Začínají být viditelné pozdě v noci, krásný otevřený hvězdokupa.
NGC 7000 - Severoamerická mlhovina v souhvězdí Labuť.
5. října 2024
M42 - Velká mlhovina v Orionu – Začíná být viditelná později v noci, skvělý objekt pro vizuální pozorování.
M31 - Galaxie v Andromedě – Opět viditelná celou noc.
NGC 869 a NGC 884 - Dvojitá hvězdokupa v souhvězdí Persea.
Uran – Viditelný celou noc, lze najít pomocí hvězdné mapy.
M33 - Galaxie v Trojúhelníku.
6. října 2024
Mars – Začíná být viditelný ráno.
M15 - Kulová hvězdokupa v Pegasu – Viditelná celou noc.
M45 - Plejády (Kuřátka) – Viditelné později v noci.
NGC 457 - Sova (ET) hvězdokupa v souhvězdí Kasiopeje.
M1 - Krabí mlhovina v souhvězdí Býka.
Viditelná pozdě v noci, nejlepší čas pro focení je po půlnoci.
Přeji ti jasnou oblohu a úspěšné pozorování i fotografování! Pokud budeš mít jakékoli další dotazy nebo budeš potřebovat více informací, dej mi vědět.
"Dar Covidu": SW Newton 200/1000, EQ5, setový okulár 10mm a 25mm, Binorum Plossl 4mm, BAADER Hyperiony 5 - 24mm, Roboostření Sesto Senso 2, Filtry Binorum Moon a UHC, BAADER suplik
[under construction]: Radioteleskop 110cm, astrobox
Re: ChatGPT
#52
AI se dá naučit prakticky čemukoli a pak může generovat výrazně lepší výsledky.
Bez učení odpověď GPT 4o:
Plán pozorování vesmírných objektů pro noci mezi 3. 10. 2024 a 6. 10. 2024
Lokalita: Zubří, Česká Republika
Dalekohled: Newton 200/1000
3. října 2024
Vizualní pozorování:
Jupiter: Začátek pozorování ve 20:00, je vysoko na obloze a je viditelný po celou noc.
Saturn: Začátek pozorování ve 21:00, viditelný v jižní části oblohy.
Andromeda (M31): Nejlepší čas pro pozorování kolem 22:00, je vysoko na obloze v zenitu.
Měsíc: Viditelný ve večerních hodinách, skvělý pro detailní pozorování kráterů a moří.
Deep-sky objekt:
M27 (Dumbbell Nebula): Začátek focení ve 23:00, doba focení 1 hodina. Je vysoko na obloze a dobře viditelná.
4. října 2024
Mars: Viditelný po půlnoci, nízko nad východním horizontem.
Albireo (dvouhvězda v Labuti): Začátek pozorování ve 21:00, skvělý objekt pro zkoumání dvojhvězd.
Hercules Cluster (M13): Nejlepší čas pro pozorování kolem 22:30, je vysoko na obloze.
Deep-sky objekt:
M57 (Ring Nebula): Začátek focení ve 23:30, doba focení 1 hodina. Je vysoko na obloze a dobře viditelná.
5. října 2024
Saturn: Začátek pozorování ve 20:00, viditelný v jižní části oblohy.
Vega (v Lyře): Začátek pozorování ve 21:00, jasná hvězda v zenitu.
Double Cluster (NGC 869 a NGC 884): Nejlepší čas pro pozorování kolem 22:00, je vysoko na obloze.
Deep-sky objekt:
NGC 6960 (Western Veil Nebula): Začátek focení ve 23:00, doba focení 1 hodina. Je vysoko na obloze a dobře viditelná.
6. října 2024
Deneb (v Labuti): Začátek pozorování ve 21:00, jasná hvězda v zenitu.
Triangulum Galaxy (M33): Nejlepší čas pro pozorování kolem 22:30, je vysoko na obloze.
Deep-sky objekt:
M42 (Orion Nebula): Začátek focení ve 23:30, doba focení 1 hodina. Je vysoko na obloze a dobře viditelná.
Doporučení
Doporučené příslušenství: Filtry (např. UHC nebo OIII) pro pozorování a focení mlhovin.
Focení deep-sky objektů: Doporučuji použít pointovací zařízení pro lepší kvalitu snímků.
Pozorování planet: Použití vyšších zvětšení (okuláry s kratší ohniskovou vzdáleností) pro detailní pozorování planet a jejich měsíců.
Oblečení: Vhodné oblečení pro chladné noční podmínky.
Re: ChatGPT
#53
Ještě jsem mu zadal úkol na pozorování Messier:
Plán Messier maratonu pro noci mezi 3. 10. 2024 a 6. 10. 2024
Dalekohled: Velký binokulár 120 mm
3. října 2024
Večerní objekty:
M31 (Andromeda Galaxy)
M32 (Satelitní galaxie Andromedy)
M110 (Satelitní galaxie Andromedy)
M33 (Triangulum Galaxy)
M74 (Galaxie v Rybách)
Noční objekty:
M77 (Galaxie v Cetusu)
M34 (Otevřená hvězdokupa v Perzeu)
M45 (Plejády)
M42 (Orion Nebula)
M43 (De Mairanova mlhovina, součást M42)
Ranní objekty:
M78 (Reflexní mlhovina v Orionu)
M79 (Kulová hvězdokupa ve Zajíci)
4. října 2024
Večerní objekty:
M52 (Otevřená hvězdokupa v Cassiopeii)
M103 (Otevřená hvězdokupa v Cassiopeii)
M76 (Malá mlhovina v Perzeu)
Noční objekty:
M1 (Krabí mlhovina v Býku)
M35 (Otevřená hvězdokupa v Blížencích)
M37 (Otevřená hvězdokupa v Vozkovi)
M36 (Otevřená hvězdokupa v Vozkovi)
M38 (Otevřená hvězdokupa v Vozkovi)
Ranní objekty:
M41 (Otevřená hvězdokupa v Velkém Psovi)
M93 (Otevřená hvězdokupa v Lodní Zádě)
M47 (Otevřená hvězdokupa v Lodní Zádě)
M46 (Otevřená hvězdokupa v Lodní Zádě)
5. října 2024
Večerní objekty:
M50 (Otevřená hvězdokupa v Jednorožci)
M48 (Otevřená hvězdokupa v Hydře)
Noční objekty:
M44 (Jesličky v Raku)
M67 (Otevřená hvězdokupa v Raku)
M81 (Bodeho galaxie v Velké Medvědici)
M82 (Cigárková galaxie v Velké Medvědici)
M97 (Soví mlhovina v Velké Medvědici)
Ranní objekty:
M108 (Galaxie v Velké Medvědici)
M109 (Galaxie v Velké Medvědici)
M101 (Galaxie v Velké Medvědici)
M102 (Spindle Galaxy ve Drakovi)
6. října 2024
Večerní objekty:
M51 (Vírová galaxie v Honících Psech)
M63 (Galaxie Slunečnice v Honících Psech)
M94 (Galaxie v Honících Psech)
Noční objekty:
M106 (Galaxie v Honících Psech)
M65 (Galaxie ve Lvu)
M66 (Galaxie ve Lvu)
M95 (Galaxie ve Lvu)
M96 (Galaxie ve Lvu)
Ranní objekty:
M105 (Galaxie ve Lvu)
M3 (Kulová hvězdokupa v Honících Psech)
M53 (Kulová hvězdokupa v Panně)
M64 (Galaxie v Honicích Psech)
M85 (Galaxie v Panně)
M60 (Galaxie v Panně)
Doporučení
Příslušenství: Mapy oblohy a hvězdné atlasy, rudé světlo, pozorovací deník.
Pozorování: Začněte s nejjasnějšími objekty na západě a postupně se přesouvejte na východní oblohu.
Příprava: Ujistěte se, že máte jasný přehled o poloze objektů předem, abyste maximalizovali čas pozorování.
Pauzy: Nezapomeňte na krátké přestávky, aby oči mohly odpočívat a znovu se adaptovat na tmu.
Tento plán zahrnuje různé Messierovy objekty pro každou noc, abyste mohli pokrýt co největší část Messierova katalogu během několika nocí.
ladin
Re: ChatGPT
#54
Dneska jsem zkusil jeden astro prompt : Vygeneruj fotku Měsíce tak jak by vypadal, kdyby se na něj aplikovaly barevné úpravy, které běžně používají amatérští fotografové deepsky objektů
Re: ChatGPT
#55
@ ladin: Velmi praktická věc :)
Já jsem nechal zpracovat plán pozorování pro binoš APM 120.
ladin
Re: ChatGPT
#56
Psion píše: 22. 08. 2024, 15:34 @ ladin: Velmi praktická věc :)
S tím plánováním to má podle mě trochu rezervy, respektive rezervy v úkolech, kde jsou třeba přesné výpočty (východy, západy, pozice Slunce atd.) Na prompt:
Navrhni astronomický pozorovaci plán pro dnešní noc v Liberci od 23:00 do 2:00, pro 40cm dalekohled, vybírej pouze planetární mlhoviny.
dostanu odpověď:
Pro astronomický pozorovací plán na dnešní noc v Liberci (23:00–2:00) s 40cm dalekohledem se zaměříme na planetární mlhoviny, které budou během této doby dobře viditelné. Vezmu v úvahu jejich jasnost, dostupnost na obloze a zajímavost pro pozorování.
### 1. NGC 6826 (Blinking Planetary Nebula)
- **Souhvězdí:** Labuť
- **Vzdálenost:** 2200 světelných let
- **Magnituda:** 8.8
- **Pozorovací čas:** 23:00 – 23:45
- **Popis:** Tato mlhovina je známá svým efektem "blikání", kdy střídavě mizí a objevuje se při přímém pohledu do okuláru.
### 2. NGC 7009 (Saturn Nebula)
- **Souhvězdí:** Vodnář
- **Vzdálenost:** 5000 světelných let
- **Magnituda:** 8.3
- **Pozorovací čas:** 23:45 – 00:30
- **Popis:** Saturnova mlhovina je pojmenována podle svého vzhledu, který připomíná planetu Saturn se svými prstenci.
### 3. NGC 6543 (Cat's Eye Nebula)
- **Souhvězdí:** Drak
- **Vzdálenost:** 3300 světelných let
- **Magnituda:** 8.1
- **Pozorovací čas:** 00:30 – 01:15
- **Popis:** Jedna z nejsložitějších a nejlépe studovaných planetárních mlhovin s charakteristickým vzhledem připomínajícím kočičí oko.
### 4. M27 (Dumbbell Nebula)
- **Souhvězdí:** Lištička
- **Vzdálenost:** 1360 světelných let
- **Magnituda:** 7.4
- **Pozorovací čas:** 01:15 – 02:00
- **Popis:** Mlhovina Činka je jednou z nejjasnějších a největších planetárních mlhovin, která je snadno pozorovatelná i menšími dalekohledy.
### Doporučení:
- **Podmínky:** Dbejte na to, aby se dalekohled nacházel mimo městské osvětlení, což zajistí nejlepší pozorovací podmínky. Ideálně s dostatečnou adaptací očí na tmu.
- **Filtry:** Doporučuji použít OIII filtr, který zvýrazní detaily v planetárních mlhovinách.
- **Stellarium nebo SkySafari:** Pokud máte přístup k astronomickým softwarům, můžete si přesně naplánovat jednotlivé objekty a jejich poloha na obloze v konkrétní čas.
Tento plán vám zajistí kvalitní a různorodé pozorování planetárních mlhovin s 40cm dalekohledem během noci v Liberci.
Na další výzvu: Navrhni další planetární mlhoviny
Tady je seznam dalších planetárních mlhovin, které by mohly být zajímavé pro pozorování v noci v Liberci:
### 1. NGC 7293 (Helix Nebula)
- **Vzdálenost:** 650 světelných let
- **Magnituda:** 7.6
- **Pozorovací čas:** 00:30 – 02:00
- **Popis:** Helixova mlhovina je jednou z nejbližších planetárních mlhovin k Zemi a je známa svým vzhledem, který připomíná obrovské oko.
### 2. NGC 6572 (Emerald Nebula)
- **Souhvězdí:** Hadonoš
- **Vzdálenost:** 2400 světelných let
- **Pozorovací čas:** 23:00 – 00:30
- **Popis:** Tato mlhovina má výrazný zelenavý odstín a je relativně malá, ale jasná a snadno pozorovatelná v menších i větších dalekohledech.
### 3. NGC 7662 (Blue Snowball Nebula)
- **Souhvězdí:** Andromeda
- **Vzdálenost:** 5600 světelných let
- **Pozorovací čas:** 23:30 – 01:00
- **Popis:** Modrý sněhový balon je další dobře viditelná mlhovina, známá svým nápadným modrým zbarvením.
### 4. IC 418 (Spirograph Nebula)
- **Souhvězdí:** Zajíc
- **Vzdálenost:** 3600 světelných let
- **Magnituda:** 9.3
- **Pozorovací čas:** 01:00 – 02:00
- **Popis:** Tato mlhovina se vyznačuje složitou vnitřní strukturou připomínající vzory z kreslícího nástroje Spirograph.
### 5. NGC 2392 (Eskimo Nebula)
- **Souhvězdí:** Blíženci
- **Vzdálenost:** 2870 světelných let
- **Magnituda:** 9.2
- **Pozorovací čas:** 00:00 – 01:30
- **Popis:** Eskymákova mlhovina má zajímavou dvojitou strukturu, která připomíná tvář obklopenou kapucí, což ji činí velmi atraktivní pro vizuální pozorování.
### 6. NGC 2440
- **Souhvězdí:** Lodní záď
- **Vzdálenost:** 4000 světelných let
- **Magnituda:** 9.4
- **Popis:** Jedna z nejžhavějších známých bílých trpasličích hvězd se nachází v centru této planetární mlhoviny, která je také jednou z nejjasnějších.
### 7. NGC 6210
- **Vzdálenost:** 6500 světelných let
- **Magnituda:** 9.0
- **Popis:** Mlhovina má charakteristický modro-zelený odstín a je zajímavá díky své vysoké povrchové jasnosti.
### Doporučení:
- **Postup pozorování:** Začněte s jasnějšími mlhovinami dříve v noci, kdy jsou výše na obloze, a přesuňte se k méně jasným a zajímavým objektům, jak noc postupuje.
- **Adaptace očí:** Nezapomeňte na přizpůsobení očí tmě, abyste maximalizovali viditelnost detailů.
Tyto mlhoviny jsou vynikající volbou pro pozorování s vaším dalekohledem a doplní již dříve zmíněné objekty.
Jsou tam evidetně objekty, které nejsou v tom čase vidět. Je to model 4-o, s rychlostí, jak to jde dopředu, to za pár let bude dokonalý.
Pepa217
Bydliště: Papeldorf, UH (49°7'18.721"N, 17°32'39.608"E)
Věk: 39
Re: ChatGPT
#57
Příspěvek od Pepa217 »
Není to přesně článek, který jsem nedávno četl, ale aspoň přibližně popisuje, co je potřeba vyřešit, aby si "AI" nevymýšlela:
https://smartmania.cz/konec-halucinacim ... na-obzoru/
ladin
Re: ChatGPT
#58
Něco praktického. Na TODO do CzSkY visí od začátku planety a jelikož GPT umí slušně programovat a GPT-o1 možná ještě o trochu líp, tak jsem úkol svěřil umělé inteligenci. Celá procedura začlenění jednoduché implementace planet do projektu mě zabrala něco málo přes hodinu. Z GPT lezl skoro spustitelný kód, dělal jsem v tom jen mírné úpravy. Celý zaznamenaný chat s GPT je zde:
https://chatgpt.com/share/66f59c12-bc08 ... 6ee94ee91e
modifikace map enginu je dobře vidět v tomhle commitu:
https://github.com/skybber/fchart3/comm ... 98299fd48f
modifikace czsky projektu je pak:
https://github.com/skybber/czsky/commit ... b4e3020931
Výsledek je už vidět i na czsky v mapách:
https://www.czsky.cz/chart?fullscreen=t ... =0&fsz=140
Slunce a M0 už dnes nestíhám...
Re: ChatGPT
#59
Ty bláho, tomu říkám příběh. Kdybys to měl programovat sám, dokážeš porovnat rozdíl v času? Vidím, že se ti do toho logicky nechtělo, ale výsledek mě ohromil.
ladin
Re: ChatGPT
#60
MaG píše: 26. 09. 2024, 20:28 Ty bláho, tomu říkám příběh. Kdybys to měl programovat sám, dokážeš porovnat rozdíl v času? Vidím, že se ti do toho logicky nechtělo, ale výsledek mě ohromil.
Udělalo to za mě ten prvotní krok, ke kterýmu velice často hledám motivaci a správný impuls. Čas to potom ušetřilo především na opakujících se vzorech kódu pro jednotlivé planety, což je konfigurace skymap enginu a samo to navrhlo barvy pro planety - s takovou blbostí bych se taky babral než bych to někde našel. Odhaduju, že bych to sám dělal tak 2h.
