INDI, KStars a Ekos
Re: INDI, KStars a Ekos
Zrejme preto, že sa VNC pozrie konfiguráciu siete. Po pripojení do firemnej siete dostane firemná sieť nižšiu metriku, ako má domáca sieť. Tú firemnú sieť potom bude považovať za lokálnu sieť. A IP adresy tej domácej siete bude považovať za externé adresy a pošle ti ich na proxy.
- mirkovacik
- Věk: 54
Tak, nové poznatky a issues... Teda hlavne issues...
Najjlepšie sa mi javí prostredie 64 bit image z Raspberry imagera + nou skripty na stable version.
Problémy s kurzorom nad mapu atd. zostávajú.
Pripojil som k tomu ASI120mm a Canon 6D. Teda skúšal som.
Asina hlási problém s pripojením. INDI sa tvári, že nie je pripojená.
ASI120mm - log:
[2024-01-24T08:59:49.723 CET INFO ][ org.kde.kstars.ekos] - "Starting INDI services..."
[2024-01-24T08:59:49.742 CET INFO ][ org.kde.kstars.ekos] - "INDI services started on port 7,624."
[2024-01-24T08:59:49.775 CET INFO ][ org.kde.kstars.ekos] - Ekos received a new device: "Telescope Simulator"
[2024-01-24T08:59:49.807 CET WARN ][ default] - QLayout: Cannot add a null widget to QGridLayout/
[2024-01-24T08:59:49.816 CET INFO ][ org.kde.kstars.indi] - Telescope Simulator : "[INFO] update mount and pier side: Pier Side On, mount type 2 "
[2024-01-24T08:59:49.845 CET WARN ][ qt.qpa.wayland] - Wayland does not support QWindow::requestActivate()
[2024-01-24T08:59:49.845 CET INFO ][ org.kde.kstars.ekos] - Ekos received a new device: "ZWO CCD "
[2024-01-24T08:59:50.088 CET INFO ][ org.kde.kstars.ekos] - Connecting to "Telescope Simulator"
[2024-01-24T08:59:50.094 CET INFO ][ org.kde.kstars.indi] - Telescope Simulator : "[INFO] Telescope simulator is online. "
[2024-01-24T08:59:50.094 CET INFO ][ org.kde.kstars.ekos] - "Telescope Simulator" Version: "1.0" Interface: 5 is connected.
[2024-01-24T08:59:50.151 CET INFO ][ org.kde.kstars.indi] - Updating "Telescope Simulator" Time UTC: "2024-01-24T07:59:49" Offset: "1"
[2024-01-24T08:59:50.153 CET INFO ][ org.kde.kstars.indi] - Updating "Telescope Simulator" Location Longitude: 16.3667 Latitude: 48.2167 Elevation: 166.22
[2024-01-24T08:59:50.168 CET INFO ][ org.kde.kstars.indi] - Telescope Simulator : "[INFO] InitPark: No Park data in file /home/astroberry2/.indi/ParkData.xml: No such file or directory "
[2024-01-24T08:59:50.168 CET INFO ][ org.kde.kstars.indi] - Telescope Simulator : "[INFO] Mount is unparked. "
[2024-01-24T08:59:50.181 CET INFO ][ org.kde.kstars.indi] - Telescope Simulator : "[INFO] Loading device configuration... "
[2024-01-24T08:59:50.181 CET WARN ][ default] - QLayout: Cannot add a null widget to QGridLayout/
[2024-01-24T08:59:50.182 CET INFO ][ org.kde.kstars.indi] - Telescope Simulator : "[INFO] Dome Policy set to: Dome ignored. Mount can park or unpark regardless of dome parking state. "
[2024-01-24T08:59:50.183 CET INFO ][ org.kde.kstars.indi] - Telescope Simulator : "[INFO] Observer location updated: Latitude 48:13:00.0 (48.22) Longitude 16:22:00.0 (16.37) "
[2024-01-24T08:59:50.184 CET INFO ][ org.kde.kstars.indi] - Telescope Simulator : "[INFO] Device configuration applied. "
[2024-01-24T08:59:50.188 CET INFO ][ org.kde.kstars.ekos] - Connecting to "ZWO CCD "
[2024-01-24T08:59:50.454 CET INFO ][ org.kde.kstars.indi] - Telescope Simulator : "[INFO] Observer location updated: Latitude 48:13:00.0 (48.22) Longitude 16:22:00.0 (16.37) "
[2024-01-24T08:59:50.454 CET INFO ][ org.kde.kstars.indi] - ZWO CCD : "[ERROR] Error connecting to the CCD (ASI_ERROR_CAMERA_REMOVED). "
[2024-01-24T08:59:50.467 CET WARN ][ default] - QObject::connect: No such slot Ekos::SchedulerProcess::process()->setMountStatus(ISD::Mount::Status)
[2024-01-24T08:59:50.496 CET DEBG ][ org.kde.kstars.ekos] - Connecting "Telescope Simulator"
[2024-01-24T08:59:50.496 CET DEBG ][ org.kde.kstars.ekos] - Connecting "ZWO CCD "
[2024-01-24T08:59:50.496 CET INFO ][ org.kde.kstars.ekos] - "Connecting INDI devices..."
[2024-01-24T08:59:50.496 CET INFO ][ org.kde.kstars.ekos] - "Telescope Simulator" is connected and ready.
[2024-01-24T08:59:50.501 CET INFO ][ org.kde.kstars.ekos] - "Telescope Simulator is online."
[2024-01-24T08:59:50.504 CET INFO ][ org.kde.kstars.ekos] - "Guider port from Telescope Simulator is ready."
[2024-01-24T08:59:50.543 CET INFO ][ org.kde.kstars.indi] - ZWO CCD : "[ERROR] Error connecting to the CCD (ASI_ERROR_CAMERA_REMOVED). "
[2024-01-24T08:59:53.470 CET INFO ][ org.kde.kstars.indi] - ZWO CCD : "[ERROR] Error connecting to the CCD (ASI_ERROR_CAMERA_REMOVED). "
[2024-01-24T08:59:59.256 CET CRIT ][ ] - QWaylandShmBuffer: mmap failed (Invalid argument)
[2024-01-24T08:59:59.351 CET INFO ][ org.kde.kstars.ekos] - "Failed to connect to ZWO CCD . Please ensure device is connected and powered on."
V INDI okne pre ASI 120 mám záložku a v záložke je "Error".
ASI120mm - log:
A ten canon 6D funguje? Tá ASI120MM nie je to starý mini model ktorý nefunguje dobre pod Linuxom? Tam bolo ruším treba nahrať nejaký experimentálny firmware aby to išlo.
- mirkovacik
- Věk: 54
Asi 120 - neviem, čo je starý model... Je to ASI 120 mm mini. Ale nekupoval som ju úplne dávno, má tak odhadujem - 3 roky. Na RI 4 v Astroberry mi ide pekne.
Canon 6D... Nakoniec sme sa pripojili (budem musieť vyriešiť to automatické pripájanie media). Ale zasa sme došli k problému s optical trains...
Je pripojený. Nevypýtalo si odo mňa zadanie trains. V záložke pre fotenie je train prázdy a kamera tiež prázdne pole. Tlačítko na editácie trainov je disablované. Na iných záložkách je toto tlačítko tiež zablokované. Na jednej z nich - nepamätám teraz presne ktorej, ale asi tam, kde sa robí polar alignment - je enablované. Po jeho stlačení sa otvorí dialóg a v ňom ked dám +, tak to celé drbne.
S tými trainami je tam nejaký komplexnejší problém - to sa vyskytovalo vo všetkým možných konfiguráciách OS a buildoch. Málokedy si to vypýtalo zadať train.
V terajšej konfigurácii, čo mám, si to pre ASInu train vypýtalo - mám na to 1 konfiguráciu výbavy (montáž simulátor, primary camera je ASIna). Na DSLR mám inú konfiguráciu výbavy (mount simulator, primarna kamera canon) (konfiguráciou výbavy myslím to, čo si pýta na začiatu, default "My astro gear"). Tam si už trainy nepýtalo... Možno je to všeobecnejší problém...
- Tomáš Grygarčík
- Věk: 38
Tohle bude problém s napájením / kabelem / USB řadičem. Ty problémové USB2.0 kamery fungovaly, jen nešlo vyčítat obraz.mirkovacik píše: ↑24. 01. 2024, 09:55[2024-01-24T08:59:50.543 CET INFO ][ org.kde.kstars.indi] - ZWO CCD : "[ERROR] Error connecting to the CCD (ASI_ERROR_CAMERA_REMOVED). "
FITS prohlížeč
FITS prohlížeč
- mirkovacik
- Věk: 54
Nechcel som tomu veriť, ale fakt to tak bolo. Kabel používam ten jeden, čo mám k ASIne. Ale vytiahol som to z jedného konektora a zapichol do iného a ide...Tomáš Grygarčík píše: ↑24. 01. 2024, 11:15 Tohle bude problém s napájením / kabelem / USB řadičem. Ty problémové USB2.0 kamery fungovaly, jen nešlo vyčítat obraz.
To nové RPI5 má USB konektory, do ktorých sa to veľmi ťažko pchá a vyberá. Normálne treba na to silu. Možno to bolo zle zapichnuté. Možno som ten port nejako poškodil pri predchádzajúcom vyťahovaní USB kľúča... Ale zapichol som do toho Canon a ten ide...
Takže už ide aj Canon aj ASI-na.
Vyzerá, že by to mohlo fungiovať.
Sťahovanie obrázku z ASIny sa skrátilo z 0,6 s na 0,09 s (oproti RPI4). (Ale looping 1s expozícií to robí s periódou 1,8s, neviem, kde to visí tých 0,7 sekundy...
Sťahovanie z Canonu sa skrátilo z 9 až 10s na 3s. To je významné.
Myslíte, že na fotenie oblohy by bol ešte nápomocný SSD disk cez NVMe? Či je to už jedno? (Najviac by som potreboval riešiť správnosť guidingu. Od RPI5 som si sľuboval, že zrýchlenie frekvencie guiding snímkov pomôže. No uvidíme.)
A teraz sa pozriem na to PHD2.
- mirkovacik
- Věk: 54
Prosím Vás o názor - pomôže reálne SSD disk pripojený cez NVMe namiesto SD karty pri astrofotení?
V podobě rychlosti trochu ano, ale nečekej zázraky. Co už ale může být argumentem je opotřebení. SD karty totiž nejsou stavěné na neustálé zápisy a čtení, které s nimi dělá OS. U takové karty po nějakém čase hrozí, že selže a data, která na ní budeš mít, budou ztracená. Ještě existuje možnost použít eMMC paměť, která má konektor na microSD slot
- mirkovacik
- Věk: 54
A SSD disky? Ja to perspektívne chcem nechať trvalo vonku, určite väčšinu času zakryté, ale striedanie teplôt -20°C - + 60° sa tam môže vyskytovať...
- mirkovacik
- Věk: 54
Tak vyzerá to, že aj PHD2 chodí.
Ďakujem Vám všetkým za pomoc.
Už len to zobrať von a uvidí sa.
Na INDI/Ekos foru se objevil zajímavý nástroj na zálohu a obnovu nastavení tohoto systému. Vhodné pro případy, kdy například přenášíte nastavení mezi dvěma počítači - například přechod z Raspberry na PC. Nemám vyzkoušeno, jenom sem dávám odkaz, protože už se mi párkrát stalo, že jsem něco takového potřeboval
https://indilib.org/forum/general/14441 ... html#99730
Poznámka k použití různých kamer stejného výrobce (která může někomu ušetřit čas):
Pokud máte dvě kamery (v mém případě Touptek) a vytvoříte v Ekosu jen jeden profil, tak se může stát, že první kamera bude fungovat, ale druhá při použití stejného profilu se bude chovat podivně. Mně se zdánlivě bez problému připojí, lze ovládat např. chlazení, ale nejde spustit expozici, popř celý Kstars "crashne".
Je nutné vytvořit pro každou kameru vlastní profil a ten důsledně používat!
Jinak moc díky Dušanovi (nou) za scripty pro překlad a sestavení!
Astroberry je zanedbaná, teď se zdá být aktuální AstroArch: https://indilib.org/forum/astro-arch/12 ... html#90118, ale kdoví, jak dlouho to vydrží.
- stmare
O Astroarchu jsem ani nevěděl, možná vyzkouším. Zatím jsem na Astroberry.
Jinak, řeším pád ekosu během astro session. Dal jsem pryč st4 a ovládám a pointuji přes USB. Běželo mi to ok, dokud se neudělal meridian flip, v tu chvíli ekos spadl. V logu nalézám zmínku typu "low voltage" na dobu, kdy se dělal ten přejezd, takže tohle je stopa. Vypadá to, že spadl indi eqmod driver a shodil ekos i s kstars. Dokud jsem měl ekos jen na dávkování focení, tak nebyl žádný pád, až teď s eqmodem. Štěstí v neštěstí je, že se dá rychle znovu zplatesolvovat a pokračovat v session...
Pokud nenajdu workaround, např. že při přejezdech vypnu ohřívací pásky, aby nepokleslo napětí při zátěži, tak zkusím ten Astroarch.
SW 100ED APO, ATR2600C
- Tomáš Grygarčík
- Věk: 38
Máš montáž napojenou přímo na baterii? Pokud napětí poklesne na takovou úroveň, že se logika řídící desky vzdá komunikace s okolním světem, nestojí za to zajistit dostatečné napájení? Já mám mezi baterií a montáží měnič (step-up step-down) natvrdo nastavený na konstantních 12,6 V a byť to z baterky cucá víc proudu, montáž je nadmíru spokojená. Vše ostatní jede přímo z baterky, u vyhřívání je mi to docela jedno, chlazení kamery má velké napěťové rezervy + na maximám jede jen za letních nocí a u RPi4 mám zabudovaný vlastní měnič na 5,1 V.
JENŽE
může se jednat o SW chybu, kupříkladu v proceduře proložení montáže a tam to bude těžší odhalit.
FITS prohlížeč
FITS prohlížeč
Astroberry je uz dost zastarale, uz sa neaktualizuje. Mozno by stalo za pokus skusit Astroarch alebo Stellamate OS, kde je Indi/Ekos aktualizvovany a spominany bug mozno aj fixnuty.
