RX 305m radioteleskopu Arecibo odrazem od Měsíce
Teoretická radioastronomie a radiotechnika, informace pro začínající, FAQ.
Matej (OK1TEH)
Příspěvek od Matej (OK1TEH) »
mozna by vas mohlo zajimat, ze v pondeli vecer 22.brezna bude v ramci akce Echoes of Apollo 2010 http://echoesofapollo.com/moon-bounce/ vysilat z 305m radioteleskopu v Arecibu mistni radioklub pod znackou KP4AO odrazem od mesicniho povrchu (EME) na 432,045 MHz +- doppler. Mod bude telegraf i SSB a sance na zachyceni signalu je v pripade uziti bezneho prijimace, ktery umi tyto mody jiz s antenou typu dipol (zisk anteny v Arecibu je na 70cm 56dBd a vykon koncoveho stupne 500W). Dalsi informace naleznete na webu: http://www.ok2kkw.com/arecibo_march2010.htm .  Fyzikalni otazky ohledne provozu EME je mozno si precist zde: http://www.ok2kkw.com/next/st1976.htm
Dalsi text nepotrebuje preklad:  "A meeting with NASA at NASA-Ames yesterday bore fruit as earlier predicted, with an opportunity for collaboration between NASA and Arecibo, and possible regular EME operations from Arecibo in the future. NASA mentioned, that whether this happens, now turns on a critical EME receive test that will happen in March. NASA and Arecibo would like a well organized test done, and, based on the results, will make a decision of a level of support and interest for future Arecibo EME/Science outreach / Fun projects. As many as several per year.
What Arecibo, and NASA want, is to get quality data from as many sources as possible during the test, and a well thought out, standardized form for data collection, and submission for analysis, that includes details of the reception, (a digital audio file recording would be great) listing obviously, time, date, frequency, Make and model, serial number, of each item used at the receive location, Receiver, Preamp, if any,Coax, and station layout used, Antenna type, make, model, Signal strength reports, objective, (precision, if possible) and subjective, and any notes on how the antenna was pointed, whether hand held, or some auto track method. (software used) A careful record of actual Az and El vs time, date, Operator name, location and contact information, and a subjective report by the operator after the test. Photographs, or video of each Station actually used, or in operation, showing key components, Antenna, coax run, interconnects, relays, Receiver preamps used, etc."
jcz
Příspěvek od jcz »
Pokud máte někdo přijímač schopný poslouchat na 432MHz, využijte této příležitosti. Je docela zajímavé poslouchat hlas, nebo telegraf, když si uvědomíme že přichází se zpožděním 2,5sec. a vzdálenosti přes 700 000km!!! Navíc naposledy, kdy se používal teleskop v Arebiku pro nějaké takové pokusy bylo před 40.lety.
Například jestli máte někdo pro pozorování meteoritu přijímač AOR8000 stačí připojit nějakou vhodnou anténu, vybrat druh provozu USB, hledat okolo 432,045 plus minus 2KHz a měli by jste je v pohodě slyšet. Jako anténa se dá třeba použít jednoduchá smyčka umístěná do ohniska paraboly, nebo třeba nějaká stará televizní širokopásmová anténa, takové "polské síto" bude přímo ideální. Dá se předpokládat že budou vysílat v rytmu EME provozu: minutu vysílat a minutu poslouchat protistanice. Pokud zaslechnete i nějaké blízké stanice pokoušející se je volat, nedivte se, že volají trochu na jiném kmitočtu (počítají s Dopplerovým posuvem kmitočtu). Nevím jaký používají v Arebiku ozařovač jestli lineární, nebo kruhový, pokud lineární, může se stát že signál bude silnější díky stáčení polarizace vertikálně, začal bych ale pozorovat horizontálně.
Pokud bude zájem můžu tu přesně v době, kdy začnou být u mě slyšet hodit sem odkaz i na přesný kmitočet.
Matej (OK1TEH)
Od: Joe Taylor <joe@Princeton.EDU>
Předmět: Re: [Moon-net] Arecibo QRV on 432
Datum: 20.3. 2010, 13:33
For those who were asking about the setup at Arecibo, I now have more complete information. It turns out that they *did* get their 3CX800 amp out of mothballs and hooked up in time for the tests. No wonder they were so loud!
Here's the scoop:
Antenna: Tx and Rx with the same circular polarization (I don't know which sense). The expectation is that ground stations will use linear polarization, and thus Faraday will not be a problem.
Rx: GaAsFET preamp into a TS-2000.
Tx: A second TS-2000 driving a 3CX800, 500 W measured output.
T/R switchover was done with a hand-operated mechanical switch -- one reason why their T/R turnaround time sometimes seemed slow. They expect to have a T/R relay in place for the session on Monday.
Once again: KP4AO expects to be QRV on 432.045 from about 2100 to 2330 UTC on Monday.
-- 73, Joe, K1JT
jcz
Příspěvek od jcz »
Tak Arebico jiz vysila, aktualni kmitocet je 432.043.4 zatim jedou telegrafem
jcz
Příspěvek od jcz »
Pondělní zkušební provoz z Arebika, dopadl dobře. Byly otestovány všechny systémy pro hlavní provoz v rámci výročí Apola a jako reklamní akce pro NASA a vědecké programy na školách. Na různých školách v USA stavějí studenti antény, aby se pokusili zaslechnou signály odražené od měsíce. Nezkusíte to taky?
Termíny hlavního provozu jsou 16.04. od 18.45, 17.04. od 19,40 a 18.04. od 20.40seč.
om7aqa
Příspěvek od om7aqa »
Po úspešnej marcovej akcii získala stanica KP4AO opäť povolenie na EME prevádzku z najväčšieho rádioteleskopu na svete (305m), ktorý sa nachádza v portorickom Arecibe. Prevádzka bude prebiehať v pásme 432 MHz v týchto dňoch a časoch:
16.4.2010: 16,45 - 19,30 UTC
17.4.2010: 17,40 - 20,20 UTC
18.4.2010: 18,40 - 21,25 UTC
Signály KP4AO by mali byť počuteľné aj na malú Yagi anténu a dobrý prijímač. Ak máte výkon aspoň 100 W, môžete sa pokúsiť aj o CW spojenie. Viac informácií na stránkach OK2KKW.
"kukátko" Celestron  Firstscope 76/300 dobson ... nech je sranda :) , refraktor 70/400 Celestron,
okulár: "setový" 20mm a 4mm (Firstscope) 20mm a 10mm OMNI, BAADER - HYPERION 8mm, 2x barlow OMNI, trieder - Bresser 10x50
om7aqa
Ešte pre tých, ktorý nevedia morzeovku:
http://sk.wikipedia.org/wiki/Medzin%C3% ... va_abeceda
:) najprv zapísať, potom preložiť :)
Príjemné počúvanie praje:
Matej (OK1TEH)
Shrnuti EME provozu z Areciba - brezen 2010: http://www.ok2kkw.com/arecibo_march2010report.htm
Dneska meli slabsi signal, pouze asi 15dB nad sumem (pouzity vykon 35W). Zitra pry vyjedou s 500W PA.
Provoz je mozne o weekendu sledovat real-time na: http://www.ustream.tv/channel/kp4ao-eme
Posluchacske reporty prosim posilejte pro prehled na email ok1teh@seznam.cz dik
Matej, OK1TEH
btw software pro vypocet sily signalu http://www.sm2cew.com/EMECalc-Ver%207.03%20Install1.zip
Pavuk_
Příspěvek od Pavuk_ »
tak to je sila, prepasol som to, vidim, ze musim castejsie kukat na AF (nie jeden krat za rok)
ivanmsk
Příspěvek od ivanmsk »
Pokial viem, tak OM3LQ spravil spojenie. Sam som ten zvukovy zaznam pocul... Ked dojde QSL (radioamateri vedia wo co go) tak ho iste dotlacim do nejakeho clanocku...
