Predam prislusenstvo z Moonlitu pre ATM
Myzer
Příspěvek #1 od Myzer » 31. 07. 2009, 21:22
Double Ball and Socket Block with 2, 1 inch Tube Inserts (Model TC-100D)
A perfect match for MoonLite Truss Tubes or can be used on any 1 inch O.D. pole with a .050 inch wall thickness.
# Material: Black acetal (Delrin)
# Dimensions: L=2.9" W=1.25" H=.95"
# Weight: Block=2.8 ounces Inserts=1.1 oz. each
http://www.focuser.com/cgi-bin/dman.cgi?page=productdetail&plugin=dstore.cgi&product=TC-100D
Predam sest tychto klbov, nove zabalene. Cena 120 EUR
MoonLite 48/49mm Filter Slide (Model FS-1)
MoonLite 2" Filter Slide is a high-end, all aluminum filter slide designed for medium to large aperture Dobs with open upper cages. Three 48/49mm filter positions and 1 oversize clear view position for barlows, etc provide a smooth transition from filtered to non-filter view. No more unscrewing/screwing filters in and out of EPs in the dark. You can use 1 1/4" EP with 2" filters as well. Mounts directly to MoonLites' crayford bolt pattern or use the generic set of mounting holes for all other installations using non MoonLite focusers.
http://www.focuser.com/cgi-bin/dman.cgi?page=productdetail&plugin=dstore.cgi&product=FS-1
Novy, zabaleny. Cena 95 EUR
Myzer
Příspěvek #2 od Myzer » 04. 08. 2009, 09:26
OK znizujem klby na 110 EUR a slider na 90 EUR.
Myzer
Příspěvek #3 od Myzer » 06. 08. 2009, 10:16
Este tak trochu pre uplnost, aby bolo zrejme co predavam. :)
Klby sa pouzivaju na stavbu dobsona trubkovej konstrukcie, viac tu:
http://www.focuser.com/cgi-bin/dman.cgi?page=category&plugin=dstore.cgi&category=5
Filtrovy slider velmi ulahcuje vymenu filtrov tym, ze sa iba posuva jedna lista kde su filtre ulozene, takze nie je potrebne filtre srobovat na okulare, vyberat z krabicky, atd. Na obrazku je to jasne vidno:
Kedze sa neozval zaujemca na moju cenovu ponuku, navrhnite mi cenu na mail myzer(zav)zoznam(bod)sk
Myzer
Příspěvek #4 od Myzer » 13. 08. 2009, 22:54
klby rezervovane, slider zatial zostava
Myzer
Příspěvek #5 od Myzer » 15. 11. 2009, 10:36
Vsetko prislusenstvo je stale k dispozicii.
Myzer
Příspěvek #6 od Myzer » 07. 12. 2009, 21:38
Skusim znizit klby na 95 EUR a slider na 80 EUR.
Myzer
Příspěvek #7 od Myzer » 14. 12. 2009, 08:15
Klby predane, filtrovy slider zostava.
Zpět na “Prodám”
Uživatelé prohlížející si toto fórum: Panda a 3 hosti
