Richard Branson a Burt Rutan představili letoun, kterým budou vozit pasažéry do vesmíru a zpátky.
http://digiweb.ihned.cz/c6-10053280-261 ... oji-fronta
Česká cestovka : http://www.typgalactic.com/ veškeré info.
VIRGIN GALACTIC
VIRGIN GALACTIC
Pátý úspěšný let v atmosféře.. snímek Whit Knight Two a Space Ship Two (trochu větší! z 22.4.2011)
http://www.space.com/11472-virgin-galac ... light.html
- ok1in
- Věk: 65
Re: VIRGIN GALACTIC
Virgin Galactic test pilots broke Mach 2 this morning, as VSS Unity took her third rocket-powered supersonic outing in less than four months. After a clean release from carrier aircraft VMS Eve at 46,500 ft, pilots Dave Mackay and Mike “Sooch” Masucci lit the spaceship’s rocket motor, before pulling up into a near vertical climb and powering towards the black sky at 2.47 times the speed of sound.
The planned 42 seconds rocket burn took pilots and spaceship through the Stratosphere and, at an apogee of 170,800 ft, into the Mesosphere for the first time. This region, often referred to by scientists as the “Ignorosphere”, is an under-studied atmospheric layer because it is above the range of balloon flight, and in the future is an area we can help the research community explore further.
After a safe landing back at Mojave Air and Space Port, Chief Pilot Dave Mackay summed up the experience: “It was a thrill from start to finish. Unity’s rocket motor performed magnificently again and Sooch pulled off a smooth landing. This was a new altitude record for both of us in the cockpit, not to mention our mannequin in the back, and the views of Earth from the black sky were magnificent.”
[bbvideo=560,315]https://www.youtube.com/watch?v=4mvaJG9Ktk4[/bbvideo]
https://www.virgingalactic.com/articles ... -at-Mach-2
Re: VIRGIN GALACTIC
Asi by sem stačilo dát ten odkaz na článek, než ho celý kopírovat ....
- ok1in
- Věk: 65
Re: VIRGIN GALACTIC
Milane, jestli ti vadí 9 řádků, tak mi teda ne. Sorry...
Pro neangličtináře:
"Po čistém odpojení od VMS Eve ve výšce 46,500 ft (14,2 km) piloti Dave Mackay a Mike "Sooch" Masucci aktivovali raketový motor. Dosáhli max. rychlost 2.47 Mach a po 42s apogee 170,800 ft (nejvyšší bod dráhy, 52,1 km). Po bezpečném přistání na Mojave Air and Space Port, Dave Mackay shrnul zkušenosti: "Bylo to vzrušující od začátku do konce. Je to pro nás oba nový výškový rekord, pohledy na Zemi z černé oblohy byly nádherné."
Pro neangličtináře:
Re: VIRGIN GALACTIC
No, mě jen překvapilo, že když raketoplán letěl před 3 dny, proč sem dáváš a kopíruješ celý článek z letu v červenci, že by stačilo dát odkaz, zvláště, když už to není aktuální. (ani výkony, ani jména )
- ok1in
- Věk: 65
Re: VIRGIN GALACTIC
Musím uznat, že máš pravdu - já se usek, správný článek je tady -https://www.virgingalactic.com/articles ... ace-flight
