INDI, KStars a Ekos
- Tomáš Grygarčík
- Věk: 37
Re: INDI, KStars a Ekos
Smazat adresář build je časté nejúčinnější řešení při jakékoli kompilaci, protože může obsahovat konfigurace pro nalezené předchozí verze balíčků. Proč by je hledal znovu, když už je jednou našel.
FITS prohlížeč
FITS prohlížeč
To nou:
z toho isteho dovodu - ako hadesovi - padanie driveru pre ASI120 po upgrade na ver. 3.6.0 z PPA, som sa rozhodol pouzit na kompilaciu Tvoj script, ale pri buildingu kstars mi to padlo v kroku:
Scanning dependencies of target KStarsLib
[ 32%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/KStarsLib_autogen/mocs_compilation.cpp.o
[ 32%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/servermanager.cpp.o
[ 32%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/guimanager.cpp.o
[ 32%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/clientmanager.cpp.o
[ 32%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/drivermanager.cpp.o
[ 32%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/blobmanager.cpp.o
[ 33%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/driverinfo.cpp.o
[ 33%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/deviceinfo.cpp.o
[ 33%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/indidevice.cpp.o
[ 33%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/indigroup.cpp.o
[ 33%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/indiproperty.cpp.o
[ 33%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/indielement.cpp.o
[ 33%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/indistd.cpp.o
[ 34%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/indilistener.cpp.o
[ 34%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/inditelescope.cpp.o
[ 34%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/indiccd.cpp.o
[ 34%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/wsmedia.cpp.o
[ 34%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/indifocuser.cpp.o
[ 34%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/indifilter.cpp.o
[ 34%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/indidome.cpp.o
[ 35%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/indiweather.cpp.o
[ 35%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/indicap.cpp.o
[ 35%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/indilightbox.cpp.o
[ 35%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/indidbus.cpp.o
[ 35%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/opsindi.cpp.o
[ 35%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/streamwg.cpp.o
[ 36%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/videowg.cpp.o
[ 36%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/indiwebmanager.cpp.o
[ 36%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/indi/customdrivers.cpp.o
[ 36%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/fitsviewer/fitslabel.cpp.o
[ 36%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/fitsviewer/fitsviewer.cpp.o
[ 36%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/fitsviewer/stretch.cpp.o
[ 36%] Building CXX object kstars/CMakeFiles/KStarsLib.dir/fitsviewer/fitstab.cpp.o
c++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
make[2]: *** [kstars/CMakeFiles/KStarsLib.dir/build.make:861: kstars/CMakeFiles/KStarsLib.dir/KStarsLib_autogen/mocs_compilation.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [CMakeFiles/Makefile2
kstars/CMakeFiles/KStarsLib.dir/all] Error 2
make: *** [Makefile:130: all] Error 2
KStars failed
Prosim, netusis v com moze byt problem?
napriek tomuto neuspechu kstars aj Ekos nabehnu, a hlavne funguje aj driver pre ASI120, ale kedze nedobehol komplet building, obavam sa co ma moze prekvapit...
Dakujem
KStars failed
Dakujem
Tohle bude až konec, spíš by bylo potřeba vidět první chybu/chyby.
Edit: tedy ještě mne napadá možnost, že by ten kompilátor odstřelil OOM killer, netuším, kolik má ten stroj paměti a jak náročný je zrovna tenhle překlad. V tom případě by to ale mělo být vidět v logu jádra.
- Tomáš Grygarčík
- Věk: 37
Pokud by to bylo nedostatkem paměti, stačí upravit řádek skriptu JOBS=$(grep -c ^processor /proc/cpuinfo) na JOBS=1 (je to začátku skriptu). Na jedno vlákno by to možná mohlo projít.
FITS prohlížeč
FITS prohlížeč
Hej toto bude najskôr nedostatok pamäte. Keď kompilujem na RPi 4GB tak je to tak akurát aby to zvládalo 4 vlákna. Ale iba na 32bitovom. Keď som skúšal 64bit systém tak som mohol použiť maximálne
Takže zmeniť v skripte tento riadok a malo by to už prebehnúť.
INDI ovládače sa kompilovali úspešne takže preto to už funguje. Opravená verzia sa už nainštalovala.
Kód: Vybrat vše
JOBS=2INDI ovládače sa kompilovali úspešne takže preto to už funguje. Opravená verzia sa už nainštalovala.
super majstri dakujem, ano bolo to pamatou, bezi mi to na odroid N2 so 4GB RAM, na 64bit ubuntu. Takze podla doporucenia mike, Tomasa a samozrejme nou som setol JOBS=2 a uz to frci jak ma....
este raz, DAKUJEM!
este raz, DAKUJEM!
Tak upravil som skript tak aby automaticky použil JOBS=2 na 64 bitových systémoch s menej ne 5GB pamäte takže do budúcna by to malo byť už bez problémov.
Nová verzia 3.6.1 KStars/Ekos má novinku "optical trains" čo je zmena v konfigurácii fotografickej zostavy. Teraz sa nastavujú jednotlivé optické vláčiky teleskop - reduktor - filtrové koleso - ostrenie - kamera - guider. Je to príprava do budúcnosti na to aby Ekos vedel fotiť paralelne s dvomi a viac kamerami paralelne. Môj build skript som tiež aktualizoval. Ďalšia novinka je že už nie sú podporované 32bitové systémy čo je hlavne problém pre Raspberry.
- mirkovacik
- Věk: 54
2 fotaky naraz, to by bolo neco... na to cakam.
Sent from my SM-A415F using Tapatalk
- Věk: 63
Pokud by to někoho zajímalo, rozchodil jsem EKOS pod Windows, není to nic složitého, třeba by to někdo využil, možná je ale návod zbytečný....
- biker.fm
- Věk: 58
Pepo, nevidel by jsem to tak ze navod by byl zbytecny. Vim aspon o dvou astrofoticich co chteli INDI/EKOS/KSTARS pouzivat a kdyz se dozvedeli ze by museli mit Linux, oba zijou asi jeste v dobe kamenne a mysli si ze by museli psat prikazy ve Shellu.
- Věk: 63
OK. Základní problém je, že nefunguje INDI server na Windows, což je s podivem, protože fungují minimálně dva Windows softwary, které INDI server potřebují k činnosti a jejich autoři o tomto postupu instalace INDI serveru do postředí Windows ani nevědí.
V prvním MS návodu se nainstaluje virtuální prostředí WSL2 s Linuxem Ubuntu (případně dle výběru jiný linux). Je potřeba jen otevřít CMD Shell jako správce a spustit příkaz wsl --install a vše se udělá automaticky. Po spuštění nainstalovaného UBUNTU se pouze zadá v úvodu uživatelské jméno a heslo. Po instalaci doporučuji provést update SW příkazem wsl --update.
Druhý krok je dle MS návodu nainstalovat komponentu usbipd. Je potřeba dát pozor, kde jednotlivé příkazy vykonáváme. Bash je spuštěný CMD jako správce a PowerShell je terminál po spuštění Ubuntu (linux pouze s příkazovou řádkou). Já jsem neinstaloval msi balíček pro usbipd, ale nainstaloval jsem jej příkazem winget install --interactive --exact dorssel.usbipd-win. Po instalaci se podíváte v CMD konzoli, která zařízení jsou viditelná příkazem usbipd wsl list a vybrané zařízení připojíte do Ubuntu příkazem usbipd wsl attach --busid X-X, kde busid jsou první čísla v řádku. Je možné připojit všechna příkazem wsl --auto-attach, nebo vybrat pouze jedno např. usbipd wsl attach --busid 1-10.
Když se pak přepneme do teminálu s Ubuntu, nainstalujeme standardně linuxové Kstars a spouštíme jako správce příkazem sudo Kstars. No a to je vše, v Ubuntu vidíme připojená zařízení z Windows, zkontrolujeme příkazem lsusb v terminálu Ubuntu (PowerShell).
Tedy připojíme v Bash porty pomocí usbipd a spustíme Ubuntu (je v seznamu programů) a následně Kstars. Šikovnější si možná udělají .bat soubor pro spouštění v dávce. Uživatel má tedy k dispozici Windows a zároveň Linux, což může být v mnoha případech velmi výhodné. Toto jsem ještě nevyzkoušel na obloze a testoval pouze s reálnou kamerou a simulátory.
- mirkovacik
- Věk: 54
Prosím, používam EKos na Raspberry PI. Mám problém, že po tom, čo montáž nabehne na cieľ a začne fotiť, tak akoby montáž ešte dobiehala.
Pri použití GoTo a následne funkčnosť, že si to odfotí a vyhodnotí chybu nabehnutia a znova to posunie a tak dokola, až je na cieli.
Pri tejto funkčnosti je snímka z cieľa "pohnutá" - hviezdy sú ako čiarky a na konci čiarky gulička. Akoby montáž ešte dobiehala a už sa fotilo.
Dá sa niekde nastaviť čas, kedy najskôr to môže začať?
Jediné čo ma napadá je nastaviť guiding settle na niekoľko sekúnd. Ale to predpokladá že používaš guiding.
- Snímka obrazovky zo dňa 2023-02-07 14-13-22.png (95.5 KiB) Zobrazeno 1750 x
- mirkovacik
- Věk: 54
Dajú sa v EKOSe pti internom EKOS guidingu vypnúť korekčné impulsy do montáže a analyzovať graf chodu montáže? (Na PHD2 mi poradili vypnúť agresivitu, ale to bolo pre PHD2...)
