Stránka 13 z 21
Stellarium
Napsal: 21. 12. 2015, 19:03
od mifo
Last Run Log pise toto.
Da sa z toho nieco vycitat?
2015-12-21T17:59:51
Windows 10
Compiled using MSVC++ 12.0 (Visual Studio 2013)
Qt runtime version: 5.5.1
Qt compilation version: 5.5.1
Addressing mode: 64-bit
Total physical memory: 3000 MB
Available physical memory: 1480 MB
Physical memory in use: 50%
Processor speed: 2194 MHz
Processor name: Pentium(R) Dual-Core CPU T4400 @ 2.20GHz
C:Program FilesStellariumstellarium.exe
[ This is Stellarium 0.14.1? - http://www.stellarium.org ]
[ Copyright (C) 2000-2015 Fabien Chereau et al. ]
Writing log file to: "C:UsersmifoAppDataRoamingStellariumlog.txt"
File search paths:
0 . "C:UsersmifoAppDataRoamingStellarium"
1 . "."
Config file "C:UsersmifoAppDataRoamingStellariumconfig.ini" does not exist. Copying the default file.
Config file is: "C:UsersmifoAppDataRoamingStellariumconfig.ini"
Detected: OpenGL ES "2.0"
Driver version string: "OpenGL ES 2.0 (ANGLE 2.1.99f075dade7c)"
GL vendor is "Google Inc."
GL renderer is "ANGLE (Mobile Intel(R) 4 Series Express Chipset Family (Microsoft Corporation - WDDM 1.1) Direct3D11 vs_4_0 ps_4_0)"
GL Shading Language version is "OpenGL ES GLSL ES 1.00 (ANGLE 2.1.99f075dade7c)"
VS Version Number detected: 4
PS Version Number detected: 4
vs/ps version is fine, we should not see a graphics problem.
GLSL ES Version Number detected: 1
GLSL ES version is fine, we should not see a graphics problem.
Cache directory is: "C:UsersmifoAppDataLocalstellariumstellariumcache"
Sky language is "sk_SK"
Application language is "sk_SK"
Loading Solar System data ...
Found an old starsConfig.json file, upgrade..
Creates file "C:UsersmifoAppDataRoamingStellariumstarsdefaultstarsConfig.json"
Loading star data ...
"Loading ".starsdefaultstars_0_0v0_5.cat": 0_0v0_2; 4963"
"Loading ".starsdefaultstars_1_0v0_5.cat": 1_0v0_2; 21598"
"Loading ".starsdefaultstars_2_0v0_5.cat": 2_0v0_2; 150090"
"Loading ".starsdefaultstars_3_1v0_3.cat": 3_1v0_3; 428466"
Finished loading star catalogue data, max_geodesic_level: 3
QObject::connect: Cannot connect (null)::stateChanged(QNetworkSession::State) to QNetworkReplyHttpImpl::_q_networkSessionStateChanged(QNetworkSession::State)
navigation/preset_sky_time is a double - treating as jday: "2451514.25001"
Reloading DSO data...
Loaded 10756 DSO records
Loading DSO name data ...
Loaded 217 / 275 DSO name records successfully
libpng warning: iCCP: known incorrect sRGB profile
Loading star names from ".skycultureswesternstar_names.fab"
Loaded 340 / 340 common star names
Loading star names from ".starsdefaultname.fab"
Loaded 4506 / 4506 scientific star names
Loading variable stars from ".starsdefaultgcvs_hip_part.dat"
Loaded 6916 / 6916 variable stars
Loading cross-index data from ".starsdefaultcross-index.dat"
Loaded 108279 / 108279 cross-index data records
Loaded 88 / 88 constellation records successfully for culture "western"
Loaded 85 / 85 constellation art records successfully for culture "western"
Loaded 88 / 88 constellation names
Loading constellation boundary data ...
Loaded 782 constellation boundary segments
Initializing basic GL shaders...
Creating GUI ...
Loaded plugin "Exoplanets"
Exoplanets: no Exoplanets section exists in main config file - creating with defaults
Exoplanets: version of the format of the catalog: 1
Exoplanets: loading catalog file: "C:UsersmifoAppDataRoamingStellariummodulesExoplanetsexoplanets.json"
Loaded plugin "FOV"
FOV: no fov section exists in main config file - creating with defaults
Loaded plugin "MeteorShowers"
MeteorShowersMgr: Loading catalog file: "C:UsersmifoAppDataRoamingStellariummodulesMeteorShowersshowers.json"
MeteorShowersMgr: Starting to update the catalog...
Loaded plugin "Novae"
Novae: no Novae section exists in main config file - creating with defaults
Novae: version of the catalog: 1
Novae: loading catalog file: "C:UsersmifoAppDataRoamingStellariummodulesNovaenovae.json"
Loaded plugin "Oculars"
Ocular plugin - press Command-O to toggle eyepiece view mode. Press ALT-o for configuration.
Oculars::validateIniFile ocular.ini exists at: "C:UsersmifoAppDataRoamingStellariummodulesOcularsocular.ini" . Checking version...
Oculars::validateIniFile found existing ini file version 3
Loaded plugin "Satellites"
Satellites::init copied default satellit
Stellarium
Napsal: 21. 12. 2015, 21:31
od juh
Vyzera to byt OK, je tam sice jedno varovanie "warning: known incorrect sRGB profile", ale to mam v log-u aj ja.
Je tam zaujimava ina vec: GL renderer is "ANGLE (Mobile Intel(R) 4 Series Express Chipset Family (Microsoft Corporation - WDDM 1.1) Direct3D11 vs_4_0 ps_4_0)"
Na wiki Stellaria o tom pisu v sekcii Common problems with version 0.14: We have first reports about missing buttons which seem to be related to errors in the ANGLE driver in Direct3D11 mode. If the logfile indicates something about GL renderer is "ANGLE (XXXXXXXXXXXXXX Direct3D11 vs_x_0 ps_y_0)" , you may be lucky if you set an environment variable QT_ANGLE_PLATFORM=d3d9 or even QT_ANGLE_PLATFORM=warp. Of course, the requirements vs_2_0/ps_3_0 or better remain the same for hardware acceleration.
Mozno pomoze nastavenie premennej prostredia podla toho popisu:
alebo
Stellarium
Napsal: 29. 12. 2015, 23:02
od Frosty
Nevíte jak ve stelláriu měřit úhlovou vzdálenost dvou hvězd?
Stellarium
Napsal: 30. 12. 2015, 00:27
od Lamid
Musí byť spustený modul uhlomer.
V nastaveniach F2/moduly/uhlomer zaškrtnuť - nahrať pri spustení.
Reštartovať Stellarium.
Na  lište sa zobrazí ikona uhlu, kliknuť na ňu /objaví sa nápoveda/, kliknuť na hviezdu a držať ľavé tlačítko myši a prejst na druhy bod, kontinualne sa zobrazuje uhol medzi kliknutím a polohou myši.
Stellarium
Napsal: 13. 01. 2016, 17:23
od PetrK
Dají se ve Stellariu nějak vypnout fotografie mlhovin a galaxií?
Třeba M42 je tak přepálená, že není vidět trapéz.
Stellarium
Napsal: 13. 01. 2016, 18:01
od juh
Napriklad stlacenim klavesy "i"
Niektore verzie maju znacku fotoaparatu v liste, jej stlacenim sa to aktivuje / deaktivuje. Funkcia ma nazov "toggle nebula background images"
Stellarium
Napsal: 13. 01. 2016, 18:57
od PetrK
Tak to mám smůlu ve verzi 0.10.4 nic z toho nefunguje. Díky.
Stellarium
Napsal: 13. 01. 2016, 23:53
od MaG
Osobně bych šel cestou, že si buď
- obrázek vyměníš za jiný od zdejších matadorů, který nemá přepálený Trapez
- upravíš soubor json, kde jsou položky jako max. jas apod. viz. návod zde:
http://www.brorfelde.eu/down/stellarium ... %20(1).pdf
Pokud dodržíš parametr, že obrázek musí mít nějaké přesně dané pixely (mocnin dvou), tak to klapne.. pozor ale aby ti sedly i hvězdy přesně na sebe.
Obrázky jsou v Program FilesStellariumnebulaedefault
Já šel cestou výměny obrázku a to:
1) otevřel originál M42dumont.png, zarovnal nad něj svůj přes vrstvu a pak ho uložil jako m42mag.png na plochu.
2) udělal jsem si na plochu kopii textures.json a otevřel ho v Poznámkovém bloku. Mlhoviny jsou tam řazeny dle čísel v M katalogu. U M42 jsem Dumonta nahradil MaGem. Soubor jsem uložil a přepsal zmeny.
3) oba soubory jsem uložil do složky programu.
Doporučuji si nechat někde originály obou souborů pro případné změny.
Změna položky Brightness v JSON souboru mi nefungovala.
Změnil jsem tedy přímo jas obrázku..
Stellarium
Napsal: 14. 01. 2016, 00:33
od PetrK
Já šel cestou (Linux):
# cd /usr/share/stellarium/nebulae/default
# mv m42dumont.png m42dumont.png.orig
nerušeně jsem si prohlídl hvězdičky a pak změnu vrátil
Děkuji za velmi užitečné informace.
Stellarium
Napsal: 14. 01. 2016, 00:36
od MaG
No vidíš, trochu sis zjednodušil práci. A připomněl si, že tu máme i Linux Díky za upřesnění, kde to tam hledat.
Stellarium
Napsal: 09. 02. 2016, 23:28
od Otoron
Zdravim,
Stellarium 0.14.2
mam otazku ohledne "ukladani" konfigurace pro "telescopeControl" plug-in 0.2.9
Mam CG-5 a musim rici, ze mi vsechno bezi jak ma az na jeden maly problem.
Neuklada se mi konfigurace pro teleskop, takze ji musim pokazde znovu nastavovat.
Vsechny ostatni ulozeni konfiguraci je OK.
Mam W10, ale stejne je to na W8.1.
soubor pro konfiguraci teleskopu "telescopes.json" se vytvori bez problemu i obsah je OK, ale po opetovnem startu jako by tam nic nebylo, proste tu konfiguraci ignoruje.
32-bitu, 64-bitu, ruzne mody for admin pristup, souborovy pristup je OK, permission taky. (jsem IT, tak snad se nepletu)
Tak nevim, zda jste se s tim setkali a nebo je to jen moje "feature"
diky za odpoved...
Oto
Stellarium
Napsal: 09. 02. 2016, 23:47
od Otoron
Zdravim jeste jednou,
Tak se omlouvam, ale po chvili jsem na to prisel.
jeste jednou jsem prosel log a vsiml jsem si, ze mam problem s COM portem
LOG:
TelescopeControl: Unable to load telescope: No valid serial port specified at slot "1"
tohle tam bylo "serial_port": "\.COM5"
takhle jsem to zmenil "serial_port": "COM5"
no a vse slape jak ma, no panove programatori udelali obrovsky kus prace na prepsani linuxove aplicace na windows, ale na tohle asi bohuzel zapomeli.. :)
preji klidnou noc
Oto
Stellarium
Napsal: 13. 02. 2016, 23:06
od Giftmacher
Zdá se mi to, nebo opravdu Stellarium neukazuje časově správně tranzit GRS na Jupiteru?
Stellarium
Napsal: 14. 02. 2016, 01:15
Ve všech programech je potřeba aktualizovat  průchod GRS centrálním meridiánem (minimálně každý rok alespoň jednou -pokud nejde o nějakou velkou přesnost)
Stellarium
Napsal: 14. 02. 2016, 09:25
od Giftmacher
Už to chodí krásně, alespoň podle údajů z http://www.projectpluto.com/jeve_grs.htm#aug
