Vyzkoušejte si zpracování
hadak
Re: Vyzkoušejte si zpracování
#1096
Příspěvek od hadak »
Díky moc za zkoušky....ten rovnač je HOTECH USA 2” ROVNAČ POLE FFT-58....taky mám ten pocit že mi v soustavě moc nesedí....
flaty to je můj věčný boj....jak je udělat dobře....
U toho srdce mě překvapilo to velké množství hvězd :-) v okolí....a když se za to hodně zatahá tak je z toho tohle...._????
pokusím se ještě data dofotit :-)
proky
#1097
Příspěvek od proky »
Zajímavá nabídka od Chilescope pro DS astrofotografy... Možnost vyzkoušet si zajímavá data.
Dear Astrophotographers!
CHILESCOPE team invites you to participate in our Astrophotography Processing Competition.
The terms are as follows:
CHILESCOPE provides raw FITS data and all calibration files
The object - Fox Fur Nebula (see previews processed by our team member Stas Volskiy)
Total exposure was 27 hours in LRGBH-a
Only advanced qualified works will be accepted (intermediate and advanced level)
At least ten processed works should be presented
All processed works should be sent in JPEG format to support@chilescope.com with topic: “APC”. Please do not forget to mention your full name in the email.
All qualified processed works will be published in the gallery on our web site with notification about person who has processed http://www.chilescope.com/image-gallery/35/
You can use any software you like to process
The jury – CHILESCOPE team
There will be only one winner (the winner takes it all)
The prize- 1000 observing points on CHILESCOPE telescopes
The prize points should be spent by winner on one telescope he\she chooses and for one object he/she chooses
Competition starts today!
The collection of works finished on 19.02.2019 at 03-00PM UTC
The winner will be announced on our Facebook page https://www.facebook.com/chilescope and on the home page on our web site http://www.chilescope.com at 20.02.2019 no later than 03-00PM UTC
The winner then registers on our Member Area page http://www.chilescope.com/members-area/
The prize points will be transferred to his account immediately
The link to download raw data files and calibration files: https://chilescope.wetransfer.com/downl ... lUFft7l_Sg
Attention! 6 Gb!
IMPORTANT! The data was acquired on two 50 cm telescopes. Those telescopes are pretty much the same (50cm F/3,8 corrected Newtonians). We provide calibration files for both telescopes. So final image should be stacked from both telescopes data.
Good luck in processing!
nosuh
#1098
Příspěvek od nosuh »
Ty data jsou fakt mazec..dikes!!
hadak
#1099
Ahoj.
posílám M101 cca 6,5 h dat.
Je to foceno ED80 kou na EQ6, přikládám i log z PDH2 a předzpracování z Pixl.
Víc z toho zatím nevydoluji...profíci by to uměli líp... :-) Díky.
http://www.uschovna.cz/zasilka/KRGBJNNSWZCEZX9I-WIW/
Ahoj Lada.
Zdeněk Vojč
#1100
Příspěvek od Zdeněk Vojč »
hadak píše:Ahoj.
Ahoj Lada.
Kroky:
Udělal jsem si master flat, dark, bias
calibrace, registrace, integrace light
DBE, color calibrace, background neutralizace, masketStretch
Deconvoluce
Potahani krivek přes masky na pozadi a objekty.
integration_DBE (2).jpg (563.16 KiB) Zobrazeno 3622 x
TS APO 150/1050, Flat Ricardi 0.75x, ZWO ASI6200MM, Astrodon E series, Astrodon 3.5 HA, OIII, EQ8 mount,remote-controlled observatory - Observatory online , databáze snímků - Smímky HVH
Zdeněk Vojč
#1101
Zdeněk Vojč píše:
hadak píše:Ahoj.
Ahoj Lada.
Kroky:
Deconvoluce
Odkaz na TIFF:
https://www.elara.cz/wallpapers/m101-hadak.tif
#1102
hadak píše:Ahoj.
Ahoj Lada.
Nechtělo by nejdřív zajistit, aby ten dalekohled kreslil normálně, tedy dát tam rovnač pole a pořádně to zaostřit ? Jinak je jakákoli další snaha jen marná práce.
hadak
#1103
Zdeňku děkuji moc mě se to líbí.
Martine, já vím....jenže rovnač pole co mám není asi ten ideální a sním se i hůře zaostřuje a zaostření dělám přes Backyard EOS a kontoluji to Bathinovou maskou a víc už to prostě nejde, asi bude někde něco špatně....třeba to moc ohřívam aby se nerosila čočka, nebo je dalekohled rozhozený a potřebuje kolimaci...nevím....takováhle rady bych uvítal...
Někdo říká že byla i blbě postavená montáž, že se stáčí pole....
Někdo řekně že je nedostatečný dythering....
Jasných nocí není tolik a jsem rád za každý úlovek i když není dokonalý :-)
alex
Věk: 67
#1104
Příspěvek od alex »
hadak píše: Někdo říká že byla i blbě postavená montáž, že se stáčí pole....
Ahoj Láďa!
Keby si pointoval, povedal by som, že to máš stočené okolo pointačnej hviezdy čo máš kdesi vľavo hore... ale asi nepointuješ... ako to je potom možné :o
Možno to niekto vysvetlí :?
Inak to vidieť aj na fotke, čo spracoval Zdeněk.
Takže?
Skús sa prepínať medzi prvým a posledným záberom a bude to jasné ;)
alex
#1105
Řešíte prozatím zbytečnosti. DOkonale ustavit montáž na stativu, aby to nkam neuteklo za několik hodin, je sci-fi. A ani to není potřeba.
Je nejpre potřeba zkolimoavat ten dalekohled, je tam něco nakřivo. Pak zajistit správnou vzdálenost senzoru od rovanče, tohle je snad horší než kdyby tam rovnač vůbec nebyl. Co je to za typ ? A pak umět zaostřit.
Pak je prostět potřeba začít pointovat, s DSLR to bez pointace smysluplně nejde, Ať si kdo chce co chce říká. Rozumné expozice pro to ED-čko jsou alespoň 3 minuty, a to ta montáž nedá. Daleko lepší bude ty expozice natahnout na 10 minut a ISO 800. A zároveň použít dithering, bez něj tam budou šmouhy vždycky. To nemá jiné řešení.
Opravdu nouzové řešení bez pointace je vždy třeba po 5 snímích lehce náhodně pohnout dalekohledem o pár desítek pixelů (ruční dithering). Pak tam ty šmouhy nebudou.
hadak
#1106
Pointaci dělám ....viz log z PHD který byl přiložený v souboru s fotkama ,kamerou ASI120MC + hledáček 10x50... asi to tedy bude blbě sestavený, a pointace je asi daleko od foceného objektu (někde v rohu jak píše Alex)....
Mám ROVNAČ HOTECH USA 2” POLE FFT-58 f/5-f/8, ale teď tam nebyl, protože posledně mi to s ním šlo špatně zaostřit.
Dythering dělá program Backyard EOS, tak asi nedostatečně, zřejmě se bude muset někde změnit nastavení a dát vyšší hodnoty.
Alex se sestavou jsem od focení M33 nic nedělal jen to celé odložil na poličku. Asi to je tím že je M101 blíž k severu tak je to stáčení viditelné a u M33 to nebylo tak znát ???
alex
Věk: 67
#1107
Příspěvek od alex »
hadak píše:...Alex se sestavou jsem od focení M33 nic nedělal jen to celé odložil na poličku. Asi to je tím že je M101 blíž k severu tak je to stáčení viditelné a u M33 to nebylo tak znát ???
Sorry, nemám Tvoje dáta... ale stačí sa preklikať medzi prvým a posledným záberom (poposúvať ich napr. v IrfanVieweri tak, aby sa stredy prekryli) a hneď je jasné či sa stáča pole :roll:
hadak
#1108
Ahoj Alex je to vidět jak se to stáčí....laicky a logicky bych usoudil že mám pointační hvězdu daleko od foceného objektu a tím že je M101 blíže k polárce tak se více otáčí kolem polu a je to vidět i podle velkého vozu který se točí dokola, kdežto objekty co se pohybují po obloze z východu na západ nejsou tolik náchylné na stáčení....pohybují se jakoby rovně...
Martine...celé to sestavím znovu, zkusím dělat ty dlouhé expozice i když díky letadlům a satelitům bude asi velký odpad, a uvidíme, udělám i kontrolní fotky zaostření, nastavení Backyard EOSu...
Tohle je na Astro fotografii v podstatě hezké, že výsledek není jednoduché dosáhnout a někdy může trvat i roky udělat super záběr. :-)
Koníček na celý život.
#1109
A co ustavení montáže? Pokud bude dobře ustavena, pak ani hvězda mimo střed záběru nebude vadit.
#1110
hadak píše:Ahoj Alex je to vidět jak se to stáčí....laicky a logicky bych usoudil že mám pointační hvězdu daleko od foceného objektu a tím že je M101 blíže k polárce tak se více otáčí kolem polu a je to vidět i podle velkého vozu který se točí dokola, kdežto objekty co se pohybují po obloze z východu na západ nejsou tolik náchylné na stáčení....pohybují se jakoby rovně...
No je úplně jedno, jestli se to stáčení promítne s malým poloměrem jako otáčení, nebo s velkým, které vypadá jako posun. Z toho šumu nelze zlikvidovat ani jedno. I relativně přesně ustavená montáž stáčení pole vyprodukuje, pokud se pointuje a objekt je poblíž pólu. Dost záleží na na tom, v jakém směru je neustaveno a v jakém směru od pólu leží objekt. Ty vztahy co popisují stáčení jsou poměrně komplikované, a rychlost stáčení se pohybuje ve velmi širokém rozmezí. Pokdu je hvězda ve foceném poli, uvidíš to jako stáčení do oblouku. Pokdu je pointační hvězda mimo focené pole, vypadá to jako stáčení s větším poloměrem, až to nakonec připomíná pouze posun.
Pokud máš pointaci, není sebemenšího důvodu dělat krátké expozice. Prostě dělej rozmuně dlouhé, aby byl objekt proexponovaný. Pak nemusíš ze snímku tak lovit, a ty vzory v šumu budou slabší. A když už máš pointaci, tak dithering je přeci prkotina, a vzory zmizí dokonale a může ti být celkem fuk, okolo čeho a jak moc se to pole stáčí. Pouze musí být ustaveno tak přesně, aby stáčení nebylo vidět na jednotlivém snímku jako protažení hvězd. A na to stačí polární hledáček.
To s těmi letadly a družicemi myslíš vážně ? Ty snad vyhazuješ všechny snímky, kde jsou nějaké družice a letadla ? A proč ? To je přeci šílená ztráta. Od toho jsou snad způsoby skládání snímků, které ty stopy ve výsledném snímku elminují pomocí sigma-clip algoritmu, nějaké jeho modifikace, nebo v nejhorším případě složením pomocí mediánu místo průměru.
