Planetární kamera ZWO ASI676MC a příslušenství pro pozorování a snímání planet - PRODÁNO
Koblizek
Příspěvek od Koblizek »
Prodám následující nevyužívané vybavení pro pozorování a snímání planet:
1) TS-Optics TSShorty 2x Apo Barlow, 1.25 inch, 3-element 66,-EUR
Optical construction: 3 elements, apochromatic
Magnification factor: 2x
Barrel size: 1.25"
Coating: Fully multi-coated
Free aperture: 26 mm
Clamp system: Precise and gentle lock by brass compression ring
Filter thread: For common 1.25" filters
https://www.teleskop-express.de/en/tele ... troph-1892
2) TS-Optics ADC Atmospheric Dispersion Corrector 103,-EUR
Optics: two multi-coated wedge-shaped prisms, which are shiftable relatively to each other
Telescope-sided connection: T2 female thread (M42x0.75) and 1.25" receptacle with filter thread
Eyepiece and Camera-sided thread: T2 male thread (M42x0.75) and 1.25" reception
Length of the ADC without connection adapter: 29 mm with T2 female thread on both sides
Coating: Multi-Coating on all optical surfaces
Weight: 175 grams
Usability: Visual and photography
- s připojenou redukcí https://www.teleskop-express.de/en/adap ... ides-13698
https://www.teleskop-express.de/en/tele ... ctor-10721
3) ZWO ASI676MC USB3.0 Color Astro Camera - Sensor D=10.05 mm, 2.00 µm pixels 291,-EUR
Sensor: Sony IMX676 1/1.6" CMOS color sensor
Resolution: 3552*3552 pixels, 12.6 megapixels
Pixel size: 2.0 µm
Sensor size: 7.1 mm x 7.1 mm
Diagonal: 10.05 mm (1/1.8" form factor)
Frame rate: up to 31.2 fps at 10 bit
Exposure time: from 32 µs - 2000 s
ROI: Supported
ST4 autoguider port: Yes
Distance from T2 thread to sensor: 12.5 mm
Shutter type: Rolling shutter
Protective window: With UV/IR cut filter
Connection: USB3.0/USB2.0
QE: ~83 %
Full well: 10.55 ke-
Anti-ampglow circuit: Yes
Readout noise: from approx. 0.56 e-
Bit resolution: 12 bit ADC
Telescope connection: M42x0.75 / 2" / 1.25" (via adapter)
Tripod thread: 1/4" on the back
Dimensions: D 62 mm x 37.1 mm (without lens)
System requirements: USB 3.0 should be supported by the operating system - from Windows 8, Mac OS X 10.8, Linux Kernel 2.6.31 (from Ubuntu 16.04)
Weight: approx. 126 g
https://www.teleskop-express.de/en/asi- ... 76mc-17911
4) Diagonální zrcátko Omegon Carbonline 90° Dielectric 99% 1,25″ 88,-EUR
https://www.novedalekohledy.cz/catalog/ ... _no_53633/
5) Okulár Binorum Planetary Deluxe LE 5mm 55° 1,25″ 72,-EUR
https://www.novedalekohledy.cz/catalog/ ... _no_77345/
Dohoda možná. Přivezu po ČR(od všech dálnic do 15 km) a západní až střední SR - severní část D1 po Martin a R1 po Zvolen(taktéž do 15 km). Na dobírku nezasílám. Fotky pošlu dle Vašich požadavků.
Děkuji Vám.
M.K.
T-S 125/975mm DUBLET APO redukce na 780mm; C2-9000
Global Meteor Network CZ000Q + CZ000R
FANDA1
Re: Planetární kamera ZWO ASI676MC a příslušenství pro pozorování a snímání planet
Příspěvek od FANDA1 »
Ahoj
Vzal bych č.4:
Jestli je volné?
F.Buchta
MatesH
Příspěvek od MatesH »
Dobrý den. Kupuji 1. Barlow. Děkuji.
Mirtom
Příspěvek od Mirtom »
Soukroma zprava na polozku c.2
Koblizek
Prosím položky 1, 4 a 2 jsou rezervovány.
Položky 3 a 5 jsou stále k dispozici.
Děkuji.
Koblizek
3) ZWO ASI676MC USB3.0 Color Astro Camera - Sensor D=10.05 mm, 2.00 µm pixels 284,-EUR kompletní orig. balení
Pixel size: 2.0 µm
ROI: Supported
QE: ~83 %
5) Okulár Binorum Planetary Deluxe LE 5mm 55° 1,25″ 70,-EUR
Stále k dispozici. Cena nižší. Definitivně jsem se usádlil na DeepSky objektech a fotometrii hvězd a komet. Zásilkovna funguje k mému překvapení krásně, tak mohu posílat s jejich pomocí...
Koblizek
Ta kamera je v záruce, kdyby to někoho zajímalo. Ještě asi něco přes rok. Zatím jsem však od ZWO nikdy nic nereklamoval. Ať už nakoupeno přes TS, nebo přímo od nich. A komunikace s nimi je vzorová. Nakupuji napřímo už přes 3 roky. Přes lokální distributory už strašně dlouho...
Důvod prodeje je moje lenost a lokální prostorové podmínky. Mám jenom jeden teleskop a přestavba z planetární konfigurace na DS/fotometrickou je s následnou adekvátní kalibrací příliš časově náročná s ohledem na mé bohužel omezené časové možnosti...
Koblizek
3) ZWO ASI676MC USB3.0 Color Astro Camera - Sensor D=10.05 mm, 2.00 µm pixels 272,-EUR kompletní orig. balení
Pixel size: 2.0 µm
ROI: Supported
QE: ~83 %
5) Okulár Binorum Planetary Deluxe LE 5mm 55° 1,25″ 67,-EUR
JaK
Příspěvek od JaK »
Zdravím, je kamera stále k dispozici?
Koblizek
Stále k dispozici. Kamera je už prodána. Děkuji.
ZodiakBoy
Věk: 40
Příspěvek od ZodiakBoy »
Koblizek píše: 10. 02. 2025, 01:07 5) Okulár Binorum Planetary Deluxe LE 5mm 55° 1,25″ 67,-EUR
Ahoj
Prosim rezervovat do 17.02 a dam pak vedet
Koblizek
OK. No problem.
Koblizek
Prosím o ukončení prodeje. Děkuji všem zájemcům. Nechť Vám komponenty dobře slouží, tak jako výtečně sloužily mojí maličkosti.
