nova u M27?
nova u M27?
Před pár hodinami přišel email z celosvětové konference o proměnných hvězdách VSNET, že jistý pan Jörg Hanisch na svém snímu M27 z noci 17/18 srpen 2005 objevil novu nebo asteroid. Nefotil jste někdo náhodou tuhle planetární mlhovinu během posledních několika dní?
Identifikační snímek je na
http://sabbe.fragzone.se/KPO/05081827.htm
Zde je text VSNET-ALERT [8627]:
Hello
Jörg Hanisch made a test image of M27 (16 x 20 sec) with his
C11 at 2699 mm FL and a unfiltered SXV-H9 camera at 3x3
binning in the night of 2005-08-17/18. When he blinked his
image with some images on the net, he found a new object at
the location:
RAJ2000: 19:59:51.29
DEJ2000: +22:42:32.3
CCD clear: 15.8 (+-0.4mag)
There is a faint USNO-B1.0 star near that locaion:
RAJ2000: 19:59:51.04
DEJ2000: +22:42:35.4
R2 mag : 17.31
The closest star Arne Henden has in his photometry files is:
RAJ2000: 19:59:51.15
DEJ2000: +22:42:30.6
V mag : 19.378
(B-V) : 1.246
But there is no bright, very red star present in the DSS2 infrared
or 2MASS J, H and Ks images at that location that could be
the reason for the bright CCD clear measurement. So its at
least an object thats a couple of mags brighter than usual.
Thorsten Lange used the Minor-Planet Checker at the IAU website
and didn't find any asteroids within 15' at 2005-08-18 00:00 UT.
Its not Goldilocks' Variable (19h59m29.8s, +22°45'13''), that is
located at the opposite side of M27:
http://www.obspm.fr/messier/xtra/leos/gl.html
Hans-Göran Lindberg also reported his new object today:
(image made 2005-08-18 21:45 – 21:57 UT)
I've found an other image made by Dominik Wos (2005-08-18/19)
that also shows something brighter than usual at that position:
http://www.astrofotografia.zone.pl/eng/ ... 82005.html
Clear skies
Wolfgang Renz
Wolfgang Renz, Karlsruhe, Germany
Rz.BAV = WRe.vsnet = RWG.AAVSO
PS: If you encounter strange chars in the mail, try to switch to UTF-8
Hello
the location:
R2 mag : 17.31
V mag : 19.378
(B-V) : 1.246
Clear skies
Wolfgang Renz
Bc. Luboš Brát
nova u M27?
Vzhledem k tomu, že se podle nových pozorování objekt nepohybuje, jedná se pravděpodobně o novu nebo o supernovu v některé ze vzdálených galaxií v pozadí.
Zde můžete porovnat pozici objektu se starší fotkou z 20inch dalekhledu, který má hlubší dosah než DSS.
Najeďte myší na spodní obrázek.
http://www.cosmotography.com/images/m27 ... nipit.html
Škoda že objekt má 16 mag!
Čau Luboš
Čau Luboš
Bc. Luboš Brát
nova u M27?
Na fotografii ze 7.8.2005 jí nenám zachycenou.
http://hvezdarna.plzen-city.cz/pozorova ... 807+10.jpg
nova u M27?
T.Vanmunster proměřil tuto hvězdu několikahodinovým ccd runem a zjistil kvaziperiodické oscilace s amplitudou 0.2-0.3 mag. Zároveň zaznamenal pomalý klesající trend světelné křivky. Je tedy možné, že se jedná o kataklyzmickou proměnnou hvězdu! V tom případě musela tato hvězda vzplanout už někdy v minulosti. Je neuvěřitelné, že si toho z těch tisíců lidí co fotí M27 jako deep-sky ještě nikdo nevšiml.
Ale pořád ještě není vyloučen typ čistá Nova.
Bc. Luboš Brát
- Věk: 51
nova u M27?
Prohlédl jsem své i cizí (mnou zpracovávané) snímky M27 a ani na jednom hvězda není (ani v náznaku), přestože dosah je srovnatelný odkazovaným snímkem. (Na loňském snímku pomocí CCD přes ELBI-ho 250-ku dokonce výrazně vyšší).
nova u M27?
VARIABLE STAR NEAR M27
Wolfgang Renz, Karlsruhe, Germany; and E. O. Waagen, AAVSO,
report the CCD discovery of a variable star near M27 by Joerg Hanisch
(Gescher, Germany) on unfiltered CCD images taken on about Aug. 18.0
UT (the mag given as about 15.8) and independently by Hans-Goeran
Lindberg (Skultuna, Sweden) on an image taken on Aug. 18.9. Hanisch
provides the following position for the variable: R.A. = 19h59m51s.29,
Decl. = +22o42'32".3 (equinox 2000.0). Renz also forwards the
following position end figures obtained by D. Boyd (Oxfordshire, U.K.,
0.35-m reflector) from CCD frames taken on Aug. 21.92: 51s.283, 32".13.
Hanisch adds that a USNO-B1.0 star of red mag 17.3 has position end
figures 51s.04, 35".4, but that there is no bright, very red star
present at the location of the variable on Digitized Sky Survey infrared
plates or on 2MASS J, H and K_s images. Waagen and A. Henden suspect
that the new variable, which is blue and has an amplitude of at least 9
magnitudes, may well be a WZ-Sge-type cataclysmic variable, and provide
the following CCD magnitudes (unfiltered unless otherwise noted)
reported to the AAVSO: Aug. 16.937, 15.6 (N. Quinn, Steyning, W.
Sussex, England; prediscovery); 21.916, V = 16.17 (Boyd); 21.917, I =
16.00 (Boyd); 21.935, V = 16.69 (D. Rodriguez, Madrid, Spain);
22.998, V = 16.16 (Boyd); 22.997, I_c = 15.82 (Boyd).
NOTE: These 'Central Bureau Electronic Telegrams' are sometimes
superseded by text appearing later in the formal IAU Circulars.
(C) Copyright 2005 CBAT
2005 August 24 (CBET 202) Daniel W. E. Green
nova u M27?
Tak jsem kolem pulnoci ze soboty na nedeli poridil novy snimek M27 pomoci kamery WAT-120N a Newtona 355/1600. Je to slozenych 65 expozic po 5s.
Nova hvezda je na snimku dobre viditelna, oznacil jsem ji zelenou sipkou. Soucasne bych se rad zeptal promenaru na hvezdu oznacenou cervenou sipkou. Na nekterych starsich fotkach je a na jinych neni. Jedna se o nejakou promennou (napr. miridu?)?
nova u M27?
to Libor:
Za chvili jedem pozorovat, tak taky zkusim ji vyfotit...jesli tam ta Mirida taky bude..snad se dostanu na tu magnitudu te..zahadne hvezdy..
nova u M27?
Ahoj Libore,
ta druha hvezdicka, co nekdy je a nekdy neni na snimcich M27 je takzvana Goldilocks' Variable - viz
cau Lubos
cau Lubos
Bc. Luboš Brát
- Věk: 51
nova u M27?
Já ji na snímku z 10.5.2005 mám:
http://hvbo.cz/foto_astronomy_cz/M27_2_hi_res.htm
A je pěkně dočervena.
nova u M27?
Dekuji, panove, prave jste mi objasnili zahadu, ktera mne trapila od rana
Kdyz jsem daval rano mezi snimky M27 svuj ze vcerejska, tak jsem proletl vsechny, co v tom tematu jsou a hned na zacatku je jeden od Skymastera, kde je ta hvezda pekne viditelna. Pro ilustraci jsem ten svuj otocil stejne a doostrenim "vytahl" hvezdy ( omlouvam se za osklivy obrazek ) :
Na tom cernobilem Skymasterove je hvezda vyrazna, na tom mem vubec neni ( tedy je, ale skoro neni videt ). A v zadnem katalogu, co tu mam v pocitaci, jsem ji nenasel, zadny asteroid take ne, tak mi to vrtalo hlavou. Jeste jednou diky.
e-mail : mpec(at)cce(dot)cz&&
