vazeny.
pichadza k nam kometa 161P ktora bude mat 11,0 mag v maxime.
skusil som ju vyhladat v nedelu rano no urobil som len odhad slabsi ako 10,4 pri 0,5
lubomir
161p/ hartley iras
161p/ hartley iras
161p/ hartley iras
v jakém přístroji jsi ji hledal (a provedl odhad)?
161p/ hartley iras
Bola asi 15 stupnov nad obzorom.
pristroj Newton 152/903 93X
161p/ hartley iras
vcera ranos om ju pozoroval ked mala 11,3 mag a bola lahodkovym objektom pre newton 152/903.
161p/ hartley iras
Kometa zjasnieva.Vcera rano mala 10,8 no kedze mala velkost 2min. a dc3 bola nie jednoduchym objektom na 15 cm newton.Ked ju budete hladat dalekohladom pod 20Cm tak na mieste kde ma byt
ju mierne rozostrite a viac vam vynikne.
161p/ hartley iras
je po maxime a slabne.
vcera mala 11,3,no aj tak je lahodkou pre 13cm.
161p/ hartley iras
Zajimavé, posílám vám příspěvek z www.aerith.net
161P/2004 V2 ( Hartley-IRAS )
It was 14 mag on May 12 when appearing in the morning low sky (Michael Mattiazzo). Then it has been brightening as expected, and it was 11.3 mag in mid June around the perihelion passage (June 16, Juan Jose Gonzalez). In its last appearance, the comet unexpectedly brightened after the perihelion passage, and reached to the maximum brightness about 45 days after the perihelion passage. In this return, it continues brightening even after the perihelion passage, too. Now it is 10.2 mag (July 2, Juan Jose Gonzalez). The diameter was small as 1.5 arcmin in mid June, however, it became much larger rapidly in early July. Now it is so large as 5 arcmin. It will be 9 mag as expected from July to August. In the Northern Hemisphere, it keeps observable for a long time after this. Now it is observable all night, however, the altitude in the morning will be lower than 15 degree in early August. In the Southern Hemisphere, it is not observable until it becomes faint.
Date(TT) R.A. (2000) Decl. Delta r Elong. m1 Best Time(A, h)
July 23 8 59.62 80 34.5 1.516 1.351 60 10.4 20:50 (170, 30)
July 30 11 12.88 75 0.5 1.575 1.385 60 10.0 20:42 (161, 34)
Kometa C/2024 Y1
161p/ hartley iras
*2005 Aug. 2.89 UT: m1=11.2, Dia.=2.5', DC=1... 30cm L (60x)... Vitali Nevski (Vitebsk, Belarus)
*2005 Aug. 2.98 UT: m1=11.6, Dia.=2', DC=3 ... 20 cm SCT (100x) ... Juan Jose Gonzalez ( Alto del Castro - Aralla, alt. 1720 m, Leon, North Spain)
*2005 Aug. 3.97 UT: m1=10.7, Dia=3.5', DC=3...26cm L (60x)...J.Carvajal (Avila, Spain)
*2005 Aug. 5.51 UT: m1=11.4, Dia.=1.6', DC=4... 40.0cm L f/4.5 (144x) ...Seiichi Yoshida (Gunma, Japan) [I estimated it very diffused on July 28. But unexpectedly, it is somewhat condensed and clearly visible with a fine clear sky. Anyway, it is much fainter than the prediction, 7-8 mag in summer. It is not brightening as expected.]
*2005 Aug. 5.98 UT: m1=11.0, Dia=2.5', DC=3...32cm L (75x)...J.Carvajal (Avila, Spain)
