Slabé komety
Cassi
Re: Slabé komety
#151
Příspěvek od Cassi »
Měření jasnosti 17 různých komet v druhé půli června pomocí robotického dalekohledu FRAM v Argentině (MPC I47). Snímky byly proměřeny programem KOPR - http://www.comet-astronomy.com/ccd-phot ... orial-faq/
74P/Smirnova-Chernykh:
2018 Jun. 17.02 UT: m1=16.5 CCD, Dia.=0.5', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:37.9 Calculated mags:16.5,16.5,16.6,16.5,16.5,16.5,16.5,16.4,16.5
] (Martin Masek, Malargue)
66P/du Toit:
2018 Jun. 17.31 UT: m1=12.0 CCD, Dia.=4.5', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:37.4 Calculated mags:12.0,12.0,12.0,12.0
C/2016 M1 (PANSTARRS):
2018 Jun. 17.14 UT: m1= 8.7 CCD, Dia.=6.0', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:64.9 Calculated mags:8.7,8.8,8.7,8.8,8.6,8.8,8.8,8.8,8.8,8.8,8.7,8.7,8.8
37P/Forbes:
2018 Jun. 17.36 UT: m1=13.0 CCD, Dia.=1.4', 30.0-cm Schmidt-Cassegrain reflector , Tail: 3.9 min. in p.a. 235 deg.
[Comet Alt.:52.5 Calculated mags:12.9,13.0,12.9,13.0,13.0,13.0,12.9
186P/Garradd:
2018 Jun. 17.10 UT: m1=17.8 CCD, Dia.=0.2', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:50.4 Calculated mags:17.7,17.8,17.7,17.8,17.7,17.8,17.8,17.8,17.8,17.7,17.8,17.8
48P/Johnson:
2018 Jun. 17.23 UT: m1=14.8 CCD, Dia.=0.5', 30.0-cm Schmidt-Cassegrain reflector , Tail: 1.5 min. in p.a. 256 deg.
[Comet Alt.:38.0 Calculated mags:14.8,14.8,14.8,14.8,14.9,14.8,14.8,14.8,14.8,14.9,14.8
78P/Gehrels:
2018 Jun. 17.27 UT: m1=17.6 CCD, Dia.=0.3', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:43.3 Calculated mags:17.6,17.6,17.6,17.6,17.6,17.6,17.6
105P/Singer Brewster:
2018 Jun. 17.06 UT: m1=18.0 CCD, Dia.=0.2', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:46.2 Calculated mags:18.0,18.0,18.0,18.0
C/2017 S6 (Catalina):
fainter than 19.5 mag, 2018 Jun 17.20
143P/Kowal-Mrkos:
2018 Jun. 15.97 UT: m1=18.3 CCD, Dia.=0.2', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:62.0 Calculated mags:18.3,18.3,18.3,18.3,18.2,18.3,18.2
29P/Schwassmann-Wachmann:
2018 Jun. 18.31 UT: m1=17.5 CCD-R, Dia.=0.2', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:37.0 Calculated mags:17.4,17.5,17.5,17.5
C/2015 V2 (Johnson):
2018 Jun. 18.39 UT: m1=15.2 CCD, Dia.=0.5', 30.0-cm Schmidt-Cassegrain reflector , Tail: 0.9 min. in p.a. 217 deg.
[Comet Alt.:50.9 Calculated mags:15.1,15.2,15.1,15.2,15.2,15.1,15.2,15.1
C/2017 B3 (LINEAR):
2018 Jun. 18.06 UT: m1=15.1 CCD, Dia.=0.2', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:52.4 Calculated mags:15.1,15.1,15.1,15.0,15.1,15.1,15.1
30P/Reinmuth:
2018 Jun. 18.02 UT: m1=19.4 CCD, Dia.=0.2', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:55.7 Calculated mags:19.4,19.5,19.4
65P/Gunn:
2018 Jun. 18.27 UT: m1=17.5 CCD, Dia.=0.2', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:36.1 Calculated mags:17.5,17.5,17.5
364P/PANSTARRS:
2018 Jun. 17.98 UT: m1=12.3 CCD, Dia.=1.8', 30.0-cm Schmidt-Cassegrain reflector , Tail: 7.4 min. in p.a. 110 deg.
[Comet Alt.:22.4 Calculated mags:12.2,12.2,12.3,12.2,12.3,12.4,12.3,12.3
38P/Stephan-Oterma:
2018 Jun. 18.42 UT: m1=16.4 CCD, Dia.=0.3', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:38.4 Calculated mags:16.4,16.4,16.4,16.4,16.4,16.3
Kometa C/2024 Y1
juh
Re: Slabé komety
#152
Příspěvek od juh »
Kométa 64P/Swift-Gehrels 17.8.2018. Ide o periodickú kométu s obežnou dobou 9.23 roka, bola objavená 17.11.1889.
Nejde o celkom slabú kométu, pri tohoročnom návrate mala na prelome októbra a novembra dosiahnúť jasnosť 12 mag. Podľa pôvodných predpokladov sa mala jej jasnosť aktuálne pohybovať niekde na úrovni 15 mag. Posledné odhady jasnosti naznačujú, že je o niečo jasnejšia, dosahuje jasnosť okolo 13 mag. Ak si udrží doterajší trend jasnosti, v príslní by mohla dosiahnuť jasnosť až 8.5 mag.
Aktuálne sa nachádza v súhvezdí Pegas, necelý 1.5° od hviezdy Algenib. Pripojený obrázok má rozmer 30'x30', S je hore.
64P/Swift-Gehrels; 17.8.2018 01:38-02:47 CEST; 31x120 sec, bin 2x2
abulafin
48P Johnson
#153
Příspěvek od abulafin »
viditelná v druhé polovině noci, dostihl jsem jí zatím jen fotograficky
48P Johnson anigif.gif (642.25 KiB) Zobrazeno 5766 x
Quod est inferius, est sicut quod est superius et quod est superius, est sicut quod est inferius.
Honza Ebr (honza42)
Re: Slabé komety
#154
Minulý týden na MAE jsem s KaoSem 400kou viděl 48P/Johnson, 38P/Stephan-Oterma a C/2018 N1 (NEOWISE), zatímco 29P/Schwassmann-Wachmann a C/2017 M4 (ATLAS) viděl jenom KaoS, potom, co já mu našel z mého hlediska zcela prázdné pole :)
Re: Slabé komety
#155
Honza Ebr (honza42) píše:Minulý týden na MAE jsem s KaoSem 400kou viděl 48P/Johnson, 38P/Stephan-Oterma a C/2018 N1 (NEOWISE), zatímco 29P/Schwassmann-Wachmann a C/2017 M4 (ATLAS) viděl jenom KaoS, potom, co já mu našel z mého hlediska zcela prázdné pole :)
Hezký!
Já minulý týden na DsD ve Šlovicích (zkouška nové lokality) viděl ve svém 11“ jen toho Giacobinniho, obloha tam byla hodně světlá...
feromich
Věk: 65
Re: Slabé komety
#156
Příspěvek od feromich »
V noci som fotografoval 4 kométy : 21/P,46/P, 48/P a 64/P.Zdalo sa , že podmienky sú vcelku dobré aspoň podľa 21P Giacobini-Zinner, no potom prišli na rad tie slabšie a v deklinácii nižšie, a to už nebola žiadna sláva.Zaujímavá sa zdá Swift-Gehrels, ktorá má aj náznak chvosta,hoci nie je moc jasná. Primerane svojej jasnosti vyzerá Wirtanen,na ktorú sa tešíme koncom roka. No na jednotlivých snímkach som ju skôr tušil, ako videl. Výsledok je žalostný, no kométy tam sú. http://www.astronomia-je-moje-hoby.estr ... -2018.html
Pazuzub
Re: Slabé komety
#157
Příspěvek od Pazuzub »
Zdravím. Nevíte prosím co za kometu protelala kolem Země r. 1992 nebo 1993? Měla prý v nazvu W. Kamaradka mi popisovala, že ulomky z komety vytvořili na nebi krásnou podívanou v podobě meteorických rojů, kdy padaly v i v houfu. Přesné jmeno komety si nepamatuje ale šla vidět po nekolik nocí. Pěkný den.
PetrK
Věk: 50
Re: kometa r. 1992
#158
Příspěvek od PetrK »
Pazuzub píše:Zdravím. Nevíte prosím co za kometu protelala kolem Země r. 1992 nebo 1993? Měla prý v nazvu W. Kamaradka mi popisovala, že ulomky z komety vytvořili na nebi krásnou podívanou v podobě meteorických rojů, kdy padaly v i v houfu. Přesné jmeno komety si nepamatuje ale šla vidět po nekolik nocí. Pěkný den.
To by mohla být kometa 109P/Swift–Tuttle, je mateřským tělesem nádherného meteorického roje Perseidy.
15x70, 10x30, 6.5x32
Cassi
Re: Slabé komety
#159
Na prelomu let 1992/1993 byla videt kometa 109P/Swift-Tuttle (v nazvu pismenko "w" ma), ktera byla v dobe navratu relativne jasna (prolomila hranici viditelnosti pouhym okem). Kometa 109P je zodpovedna za meteoricky roj Perseidy.
Edit: PetrK byl o neco rychlejsi.
Kometa C/2024 Y1
feromich
Věk: 65
Re: Slabé komety
#160
Včera večer som mal velké plány, aspoň podľa Aladina. Realita však bola úplne iná. Nakoniec som bol rád, že som mal hodinu na expozxíciu 64/P Swift-Gehrels. Podľa vizuálnych pozorovaní by mala mať okolo 12,5 magnitúdy, no fotograficky by som to odhadol minimálne o 1,5 až 2 menej. Hlava je malá, no s náznakom chvosta.http://www.astronomia-je-moje-hoby.estr ... popis.html
PetrK
Věk: 50
Re: kometa r. 1992
#161
Jen pro zajímavost kometa 109P/Swift–Tuttle má dobu oběhu 133 let a bývá velmi jasná.
Meteorický roj Perseidy je pozorovatelný každý rok od 17. července do 24. srpna.
https://cs.wikipedia.org/wiki/Perseidy
Peper
Re: Slabé komety
#162
Příspěvek od Peper »
Kométa Stephan Oterma /38P/ Velmi slabá Mag 11.5 Obrázek
abulafin
Re: Slabé komety
#163
29P Schwassmann-Wachmann v noci na dnes. William Optics 110 mm, Canon EOS450D.
Re: Slabé komety
#164
Nechce se mio zakládat extra vlákno, když už jsou na tuhle kometu zde 2 příspěvky. I když ji asi nelze při tomhle návratu řadit mezi slabé komety.
kometa 64P/Swift-Gehrels, ze dne 31.10.2018
feromich
Věk: 65
Re: Slabé komety
#165
Tak pridám aj ja jeden môj chabý pokus o farbu tejto kométy z 30.10. http://www.astronomia-je-moje-hoby.estr ... b-poz.html
