Omlouvam se za flood ale vic hlav vic vi takze tady je seznam tech soucastek a schema (v tom pdf. je i tistak a dalsi detaily).. Je mozny zjistit zda se to da sehnat i u nas tj. ze to neni extraburt pripadne nahradit pokud s necim bude problem?
CAPACITORS Note polarity on all electrolytic capacitors
C1 39 pF, disc ceramic (390)
C2 4-40 pF, variable capacitor
C3 56 pF, disc ceramic (560)
C4 22 pF, disc ceramic (220)
C5 .01 mF, dipped ceramic
C6 4-40 pF, variable capacitor
C7 not used
C8 .01 mF, dipped ceramic
C9 47 pF, disc ceramic (470) or (47)
C10 270 pF, disc ceramic (271)
C11 0.1 mF, dipped ceramic (.1K)
C12 47 pF, disc ceramic (470) or (47)
C13 47 pF, disc ceramic (470) or (47)
C14 0.1 mF, dipped ceramic (.1K)
C15 10 pF, disc ceramic (100)
C16 10 mF, 25 vdc, electrolytic
C17 0.1 mF, dipped ceramic (.1K)
C18 0.1 mF, dipped ceramic (.1K)
C19 1 mF, metal polyester (105)
C20 0.068 mF, 5% metal film (683)
C21 0.1 mF, 5% metal film (104)
C22 0.068 mF, 5% metal film (683)
C23 0.1 mF, dipped ceramic (.1K)
C24 10 mF, 25 vdc, electrolytic
C25 10 mF, 25 vdc, electrolytic
C26 0.1 mF, dipped ceramic (.1K)
C27 10 mF, 35 vdc, tantalum, stripe, long lead +
C28 220pF, disc ceramic (221)
C29 0.1 mF, dipped ceramic (.1K)
C30 10 mF, 25 vdc, electrolytic
C31 10 mF, 25 vdc, electrolytic
C32 330 mF, 25 vdc, electrolytic
C33 10 mF, 25 vdc, electrolytic
C34 0.1 mF, dipped ceramic (.1K)
C35 0.1 mF, dipped ceramic (.1K)
C36 0.1 mF, dipped ceramic (.1K)
C37 10 pF, disc ceramic (100)
C38 10 mF, 25 vdc, electrolytic
C39 100 mF, 25 vdc, electrolytic
C40 0.1 mF, dipped ceramic (.1K)
C41 0.1 mF, dipped ceramic (.1K)
C42 0.1 mF, dipped ceramic (.1K)
C43 0.1 mF, dipped ceramic (.1K)
C44 10 mF, 25 vdc, electrolytic
DIODES Note Polarity
D1 1N4001
D2 1N914
D3 1N914
LED1 light emitting diode (LED), red
VD1 MV209, varactor diode
ZD1 1N753, 6.2 v, zener diode, 400 mw
ZD2 1N5231, 5.1v, zener diode, 500mw
INDUCTORS Do Not Confuse L1, L2, L3 with Resistors
L1 0.47 mH, (gold, yellow, violet, silver)
L2 1 mH, (brown, gold, black, silver)
L3 3.9 mH, (orange, gold, white, gold)
L4 1.5 mH, adjustable inductor
L5 1.5 mH, adjustable inductor
L6 82 mH, fixed inductor
L7 82 mH, fixed inductor
INTEGRATED CIRCUITS
IC1 SA602AN, mixer / oscillator
IC2 LM387, audio preamplifier
IC3 LM387, audio preamplifier
OSC1 20 MHz crystal oscillator module
RESISTORS
R1 68 ohm (blue, gray, black)
R2 294 ohm (red, white, yellow, black, brown)
R3 17.4 ohm (brown, violet, yel, gold, brown)
R4 294 ohm (red, white, yellow, black, brown)
R5 100 ohm (brown, black, brown)
R6 2.2 Kohm (red, red, red)
R7 10 Kohm linear potentiometer
R8 2.2 Kohm (red, red, red)
R9 100 Kohm (brown, black, yellow)
R10 220 ohm (red, red, brown)
R11 1.5 Kohm (brown, green, red)
R12 1 Kohm (brown, black, red)
R13 27 Kohm (red, violet, orange)
R14 100 Kohm (brown, black, yellow)
R15 10 Kohm potentiometer /switch
R16 10 Kohm (brown, black, orange)
R17 1.5 Kohm (brown, green, red)
R18 27 Kohm (red, violet, orange)
R19 100 Kohm (brown, black, yellow)
R20 1 Kohm (brown, black, red)
R21 1 Kohm (brown, black, red)
R22 2 ohm (red, black, gold)
R23 2 ohm (red, black, gold)
R24 1 ohm (brown, black, gold)
R25 220 ohm (red, red, brown)
R26 47 ohm (yellow, violet, black)
R27 1Kohm (brown, black, red)
R28 10 ohm (brown, black, black)
R29 10 ohm (brown, black, black)
R30 10 ohm (brown, black, black)
R31 10 ohm (brown, black, black)
R32 47 ohm (yellow, violet, black)
TRANSISTORS
Q1 J-310, junction field effect, (JFET)
Q2 2N-3904, bipolar, NPN
Q3 2N-3906, bipolar, PNP
HARDWARE / MISC
E1 Enclosure 5x7x2
PCB1 Printed Circuit Board
J1 Power Jack, 2.1 mm
J2 F female chassis connector
J3 3.5 mm stereo jack, open ckt
J4 3.5 mm stereo jack, open ckt
spacers (2) 0.375 inch spacer, 4-40 thread
K1, K2 Knob, 1/8 inch shaft
P1 2.1 mm plug with 72 inch cord
Screw (5) 4-40 thread, 1/4 inch long
Lockwaser (5) #4
Flatwasher (1) #4
Nut (1) 4-40
Solder Lug(1) #4
Wire 1ft red and 1ft black
Feet (4) Rubber adhesive feet
Decals (2) Front and rear panel decals
OTHER MATERIAL
Allen Wrench 1/16 inch for knobs
Sandpaper
Tuning tool White - for tuning inductors L4, L5
Plastic screw driver For tuning capacitors C2 and C6
Doufam ze to z toho pujde ve Photoshopu nejak odfiltrovat aby zbyl jen ten sedej pcb layout..
