Slabé komety
Cassi
Re: Slabé komety
Příspěvek #151 od Cassi » 22. 06. 2018, 19:44
Měření jasnosti 17 různých komet v druhé půli června pomocí robotického dalekohledu FRAM v Argentině (MPC I47). Snímky byly proměřeny programem KOPR - http://www.comet-astronomy.com/ccd-phot ... orial-faq/
74P/Smirnova-Chernykh:
2018 Jun. 17.02 UT: m1=16.5 CCD, Dia.=0.5', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:37.9 Calculated mags:16.5,16.5,16.6,16.5,16.5,16.5,16.5,16.4,16.5
] (Martin Masek, Malargue)
66P/du Toit:
2018 Jun. 17.31 UT: m1=12.0 CCD, Dia.=4.5', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:37.4 Calculated mags:12.0,12.0,12.0,12.0
C/2016 M1 (PANSTARRS):
2018 Jun. 17.14 UT: m1= 8.7 CCD, Dia.=6.0', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:64.9 Calculated mags:8.7,8.8,8.7,8.8,8.6,8.8,8.8,8.8,8.8,8.8,8.7,8.7,8.8
37P/Forbes:
2018 Jun. 17.36 UT: m1=13.0 CCD, Dia.=1.4', 30.0-cm Schmidt-Cassegrain reflector , Tail: 3.9 min. in p.a. 235 deg.
[Comet Alt.:52.5 Calculated mags:12.9,13.0,12.9,13.0,13.0,13.0,12.9
186P/Garradd:
2018 Jun. 17.10 UT: m1=17.8 CCD, Dia.=0.2', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:50.4 Calculated mags:17.7,17.8,17.7,17.8,17.7,17.8,17.8,17.8,17.8,17.7,17.8,17.8
48P/Johnson:
2018 Jun. 17.23 UT: m1=14.8 CCD, Dia.=0.5', 30.0-cm Schmidt-Cassegrain reflector , Tail: 1.5 min. in p.a. 256 deg.
[Comet Alt.:38.0 Calculated mags:14.8,14.8,14.8,14.8,14.9,14.8,14.8,14.8,14.8,14.9,14.8
78P/Gehrels:
2018 Jun. 17.27 UT: m1=17.6 CCD, Dia.=0.3', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:43.3 Calculated mags:17.6,17.6,17.6,17.6,17.6,17.6,17.6
105P/Singer Brewster:
2018 Jun. 17.06 UT: m1=18.0 CCD, Dia.=0.2', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:46.2 Calculated mags:18.0,18.0,18.0,18.0
C/2017 S6 (Catalina):
fainter than 19.5 mag, 2018 Jun 17.20
143P/Kowal-Mrkos:
2018 Jun. 15.97 UT: m1=18.3 CCD, Dia.=0.2', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:62.0 Calculated mags:18.3,18.3,18.3,18.3,18.2,18.3,18.2
29P/Schwassmann-Wachmann:
2018 Jun. 18.31 UT: m1=17.5 CCD-R, Dia.=0.2', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:37.0 Calculated mags:17.4,17.5,17.5,17.5
C/2015 V2 (Johnson):
2018 Jun. 18.39 UT: m1=15.2 CCD, Dia.=0.5', 30.0-cm Schmidt-Cassegrain reflector , Tail: 0.9 min. in p.a. 217 deg.
[Comet Alt.:50.9 Calculated mags:15.1,15.2,15.1,15.2,15.2,15.1,15.2,15.1
C/2017 B3 (LINEAR):
2018 Jun. 18.06 UT: m1=15.1 CCD, Dia.=0.2', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:52.4 Calculated mags:15.1,15.1,15.1,15.0,15.1,15.1,15.1
30P/Reinmuth:
2018 Jun. 18.02 UT: m1=19.4 CCD, Dia.=0.2', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:55.7 Calculated mags:19.4,19.5,19.4
65P/Gunn:
2018 Jun. 18.27 UT: m1=17.5 CCD, Dia.=0.2', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:36.1 Calculated mags:17.5,17.5,17.5
364P/PANSTARRS:
2018 Jun. 17.98 UT: m1=12.3 CCD, Dia.=1.8', 30.0-cm Schmidt-Cassegrain reflector , Tail: 7.4 min. in p.a. 110 deg.
[Comet Alt.:22.4 Calculated mags:12.2,12.2,12.3,12.2,12.3,12.4,12.3,12.3
38P/Stephan-Oterma:
2018 Jun. 18.42 UT: m1=16.4 CCD, Dia.=0.3', 30.0-cm Schmidt-Cassegrain reflector .
[Comet Alt.:38.4 Calculated mags:16.4,16.4,16.4,16.4,16.4,16.3
juh
Re: Slabé komety
Příspěvek #152 od juh » 17. 08. 2018, 12:01
Kométa 64P/Swift-Gehrels 17.8.2018. Ide o periodickú kométu s obežnou dobou 9.23 roka, bola objavená 17.11.1889.
Nejde o celkom slabú kométu, pri tohoročnom návrate mala na prelome októbra a novembra dosiahnúť jasnosť 12 mag. Podľa pôvodných predpokladov sa mala jej jasnosť aktuálne pohybovať niekde na úrovni 15 mag. Posledné odhady jasnosti naznačujú, že je o niečo jasnejšia, dosahuje jasnosť okolo 13 mag. Ak si udrží doterajší trend jasnosti, v príslní by mohla dosiahnuť jasnosť až 8.5 mag.
Aktuálne sa nachádza v súhvezdí Pegas, necelý 1.5° od hviezdy Algenib. Pripojený obrázok má rozmer 30'x30', S je hore.
64P/Swift-Gehrels; 17.8.2018 01:38-02:47 CEST; 31x120 sec, bin 2x2
abulafin
48P Johnson
Příspěvek #153 od abulafin » 19. 08. 2018, 15:35
viditelná v druhé polovině noci, dostihl jsem jí zatím jen fotograficky
48P Johnson anigif.gif (642.25 KiB) Zobrazeno 1381 x
Quod est inferius, est sicut quod est superius et quod est superius, est sicut quod est inferius.
Honza Ebr (honza42)
Re: Slabé komety
Příspěvek #154 od Honza Ebr (honza42) » 20. 08. 2018, 09:13
Minulý týden na MAE jsem s KaoSem 400kou viděl 48P/Johnson, 38P/Stephan-Oterma a C/2018 N1 (NEOWISE), zatímco 29P/Schwassmann-Wachmann a C/2017 M4 (ATLAS) viděl jenom KaoS, potom, co já mu našel z mého hlediska zcela prázdné pole :)
Dobson 400 michal.b, Paracorr, Eudiascopic 35, cosi 2" od Saši, 25 a 10, TS Edge-on 16, Nagler 9, Radian 6, Kasai 4, UHC, OIII a Hbeta. 100D a 200D, Canon 24/2.8, 50/1.8, 85/1.8, 70-200/4L, 400/5.6L, Tokina 11-16/2.8, SW MAK 127 a 90, TAL MT-3S
Re: Slabé komety
Příspěvek #155 od dvader » 20. 08. 2018, 11:05
Honza Ebr (honza42) píše:Minulý týden na MAE jsem s KaoSem 400kou viděl 48P/Johnson, 38P/Stephan-Oterma a C/2018 N1 (NEOWISE), zatímco 29P/Schwassmann-Wachmann a C/2017 M4 (ATLAS) viděl jenom KaoS, potom, co já mu našel z mého hlediska zcela prázdné pole :)
Hezký!
Já minulý týden na DsD ve Šlovicích (zkouška nové lokality) viděl ve svém 11“ jen toho Giacobinniho, obloha tam byla hodně světlá...
Tlustá Berta (Celestron CPC-1100 GPS XLT), Lunt LS60TC, WO Megrez 72 APO, APM Herschel 1.25", okuláry Vixen LVW 42 mm, TV Radiany 8 a 5 mm, a Hyperiony 31, 13, 8 a 5 mm, triedr Kowa XD 8x33 Genesis :D
feromich
Re: Slabé komety
Příspěvek #156 od feromich » 22. 08. 2018, 20:41
V noci som fotografoval 4 kométy : 21/P,46/P, 48/P a 64/P.Zdalo sa , že podmienky sú vcelku dobré aspoň podľa 21P Giacobini-Zinner, no potom prišli na rad tie slabšie a v deklinácii nižšie, a to už nebola žiadna sláva.Zaujímavá sa zdá Swift-Gehrels, ktorá má aj náznak chvosta,hoci nie je moc jasná. Primerane svojej jasnosti vyzerá Wirtanen,na ktorú sa tešíme koncom roka. No na jednotlivých snímkach som ju skôr tušil, ako videl. Výsledok je žalostný, no kométy tam sú. http://www.astronomia-je-moje-hoby.estr ... -2018.html
Pazuzub
Re: Slabé komety
Příspěvek #157 od Pazuzub » 15. 09. 2018, 11:48
Zdravím. Nevíte prosím co za kometu protelala kolem Země r. 1992 nebo 1993? Měla prý v nazvu W. Kamaradka mi popisovala, že ulomky z komety vytvořili na nebi krásnou podívanou v podobě meteorických rojů, kdy padaly v i v houfu. Přesné jmeno komety si nepamatuje ale šla vidět po nekolik nocí. Pěkný den.
PetrK
Re: kometa r. 1992
Příspěvek #158 od PetrK » 15. 09. 2018, 12:45
Pazuzub píše:Zdravím. Nevíte prosím co za kometu protelala kolem Země r. 1992 nebo 1993? Měla prý v nazvu W. Kamaradka mi popisovala, že ulomky z komety vytvořili na nebi krásnou podívanou v podobě meteorických rojů, kdy padaly v i v houfu. Přesné jmeno komety si nepamatuje ale šla vidět po nekolik nocí. Pěkný den.
To by mohla být kometa 109P/Swift–Tuttle, je mateřským tělesem nádherného meteorického roje Perseidy.
Dobson 200/1200, SCT 127/1250, 32-28-25-20-17.5-14-xf12-10-o10-9-xf8.5-bh8-bhr6-6-5.5-bhr5-bhr4.3-4, RedDot, UHC, Solar fólie, Solar Continuum
15x70, 10x50, 10x30, 8x40, 6x30, 3.5x30
Cassi
Re: Slabé komety
Příspěvek #159 od Cassi » 15. 09. 2018, 12:46
Na prelomu let 1992/1993 byla videt kometa 109P/Swift-Tuttle (v nazvu pismenko "w" ma), ktera byla v dobe navratu relativne jasna (prolomila hranici viditelnosti pouhym okem). Kometa 109P je zodpovedna za meteoricky roj Perseidy.
Edit: PetrK byl o neco rychlejsi.
feromich
Re: Slabé komety
Příspěvek #160 od feromich » 16. 09. 2018, 08:56
Včera večer som mal velké plány, aspoň podľa Aladina. Realita však bola úplne iná. Nakoniec som bol rád, že som mal hodinu na expozxíciu 64/P Swift-Gehrels. Podľa vizuálnych pozorovaní by mala mať okolo 12,5 magnitúdy, no fotograficky by som to odhadol minimálne o 1,5 až 2 menej. Hlava je malá, no s náznakom chvosta.http://www.astronomia-je-moje-hoby.estr ... popis.html
Pazuzub
Re: kometa r. 1992
Příspěvek #161 od Pazuzub » 18. 09. 2018, 19:00
PetrK píše:
Díky moc
PetrK
Re: kometa r. 1992
Příspěvek #162 od PetrK » 18. 09. 2018, 22:57
Jen pro zajímavost kometa 109P/Swift–Tuttle má dobu oběhu 133 let a bývá velmi jasná.
Meteorický roj Perseidy je pozorovatelný každý rok od 17. července do 24. srpna.
https://cs.wikipedia.org/wiki/Perseidy
Peper
Re: Slabé komety
Příspěvek #163 od Peper » 26. 09. 2018, 21:41
Kométa Stephan Oterma /38P/ Velmi slabá Mag 11.5 Obrázek
abulafin
Re: Slabé komety
Příspěvek #164 od abulafin » 16. 10. 2018, 23:09
29P Schwassmann-Wachmann v noci na dnes. William Optics 110 mm, Canon EOS450D.
Věk: 70
Re: Slabé komety
Příspěvek #165 od MilAN » 01. 11. 2018, 11:22
Nechce se mio zakládat extra vlákno, když už jsou na tuhle kometu zde 2 příspěvky. I když ji asi nelze při tomhle návratu řadit mezi slabé komety.
kometa 64P/Swift-Gehrels, ze dne 31.10.2018
Zpět na “Sluneční soustava”
